Thornebt ,If it is any help www.apuljackelectronics.co.uk do a modification to your EC325 charging system which may allow a better choice of batteries etc. The details are described in their catalogue.
Cheaper and better to fit a Victron IP22 charger.Thornebt ,If it is any help www.apuljackelectronics.co.uk do a modification to your EC325 charging system which may allow a better choice of batteries etc. The details are described in their catalogue.
A 100 amp-hour (Ah) battery will provide for example 5A of current for 20 hours. Or 2.5A of current for 40 hours. Or 10A of current for 10 hours. Etc.Already my electrical expertise is struggling!. I will probably go for 12v - just need to ascertain if I should go for batteries higher than 100Ah. I understand that higher Ah batteries take longer to charge but last longer. With one EHU stop every four or five days higher Ah batteries might make sense.
It's not difficult to do the calculations, to see if you would benefit from more solar or more battery. Suppose that, without solar, a 100Ah battery is down from 100% to 50% in 24 hours. That means you have used 50Ah of charge.I think the ops idea sounds perfectly reasonable if the current set up matches well with what they need. Every time anyone mentions batteries and solar a lot go off on a fit as much solar as possible and lithium and a b2b and a new charger etc but why would you if the current set up matches what you need?
But in the ops case the calculation is a lot simpler. Before the battery was knackered was there enough battery to use the MH in the way they wanted if so get like for like. If yes but they want a bit longer off grid lead acid again with an increased capacity would probably be enough . If they want to get an inverter, air fryer, etc it's a different matter.It's not difficult to do the calculations, to see if you would benefit from more solar or more battery. Suppose that, without solar, a 100Ah battery is down from 100% to 50% in 24 hours. That means you have used 50Ah of charge.
A 100W solar panel can yield about 30Ah to 40Ah on an average day, more if the weather is very good. So after 24 hours the battery would be down by 10Ah to 20Ah. On that basis you could last two or even three days without needing to hookup or a long drive to charge up the battery. With 300Ah of battery you could probably last a fortnight if the weather was good.
An extra 100W solar panel would mean the yield is up to 60Ah to 80Ah on an average day, so that will easily refill the battery back up to the 100% level, every day. So you could last indefinitely, at least while the weather was OK.
The problem with electrics is 'mission creep'. Since electricity's not a problem any more, just add a laptop charger, a TV, what about electric bikes, maybe an inverter to run a hairdryer or microwave or coffee machine. It's a rabbit hole once you start...
I’m in agreement. I’ve just replaced two LA batteries with slightly larger, 115ah v 95ah, ones to give us slightly more amps from the same under floor battery space. We don’t use a TV, hairdryers, microwaves, electric kettles, remorskas etc so our demands are quite low I suspect. The last batteries, Banners from memory, lasted over 10 years. We are just finishing off two months in Morocco and didn’t plug in once, we have a 100w solar panel. We cook and heat water with gas, our gas bill for the two months using local gas was £6.I think the ops idea sounds perfectly reasonable if the current set up matches well with what they need. Every time anyone mentions batteries and solar a lot go off on a fit as much solar as possible and lithium and a b2b and a new charger etc but why would you if the current set up matches what you need?
