Set your solar charger at the pre set lifepo4 profile, hook up the battery, and let it charge. Open the ap for solar and watch the voltage. With a multimeter in the same time, at battery terminals read the voltage. Compare the two. It should be close to no more than 0.1amp difference. As solar 13.5- battery 13.4v max.
You can also read the voltage with the meter at solar end and compare the app with your meter, to confirm your meter reads close to the app readings.
