- Jul 28, 2010
- 15,475
- 20,764
- Rapido 7090F 3 litre 160
- May 2010
Yes you are welcome as I would have to dispose of it. Bear in mind it is 315mm diameter not like the 270 I have just fitted.
Yes I had noticed the size difference and I'm not 100% sure it will fit but if it won't I'll re-offer it on the forum before disposing of it.Yes you are welcome as I would have to dispose of it. Bear in mind it is 315mm diameter not like the 270 I have just fitted.
Second ThatAnother great project, well executed and brilliantly illustrated. Thanks for sharing Andy![]()
The correx is a long way below the tank Jock, it's primary task is stone protection.
Excellent series. Have you considered adding a BBQ point that can also be used as an extend a stay in the above pipework. that would allow use of a foreign bottle in the event of LPG not being available.Picture of the filler is already in the thread.
The only picture to complement a new install is the old gas locker where the regulator has disappeared and the solid copper pipe comes through from the tanks regulator via an isolation tap.
