How do you weigh axle weights?It's a designation given to camper van tyres as they are stronger than the standard trye due to more steel in the tyre. This enables the tyre to be inflated to a higher pressure and as other have said to prevent flat spots when standing stationary for long periods. If the pressure is correct one should not experience a rough ride. I never have,but then again I weigh my exle weights and then put the pressure in the
Tyre that is recommended by Continental for that given axle weight.
Tyres are rated for load and speed and as long as that matches your axles weight and the vehicles performance why would it matter if it’s a bus, van, motorhome, skip lorry, ice cream van etc etc.If the tyres don't specify for motorhome use, it might cause problems with insurance if something goes wrong.
This is quite straight forward. Load your motorhome as you would for your average trip. Strap your partner to the front seat, assuming you travell with just you and she. If the kids normally travel with you then gag and tie them up and bundle them inside too. Next go to a weighbridge, these are very easy to find and you should be able to get one near you. Take motorhome to weighbridge and weigh the whole lot in one go. Then put one of the axles on the weighbridge, either one will do and weigh that again, fully loaded. The weighbridge guy will print you off a ticket that shows weight of whole van and weight with one axle. You subtract one from the other and now have the weight of both axles. You then go to your tyre manufacturer and provide him with the axle weights and your tyre detail. They will come back to you with the correct pressure for each tyre. Continental have their tyre data manual online and you can get the pressures from that, although there more than happy to provide that infomation free of charge. Finally, untie partner and kids. Job done.How do you weigh axle weights?
Thank you! Guess I substitute dogs for any other humans!!This is quite straight forward. Load your motorhome as you would for your average trip. Strap your partner to the front seat, assuming you travell with just you and she. If the kids normally travel with you then gag and tie them up and bundle them inside too. Next go to a weighbridge, these are very easy to find and you should be able to get one near you. Take motorhome to weighbridge and weigh the whole lot in one go. Then put one of the axles on the weighbridge, either one will do and weigh that again, fully loaded. The weighbridge guy will print you off a ticket that shows weight of whole van and weight with one axle. You subtract one from the other and now have the weight of both axles. You then go to your tyre manufacturer and provide him with the axle weights and your tyre detail. They will come back to you with the correct pressure for each tyre. Continental have their tyre data manual online and you can get the pressures from that, although there more than happy to provide that infomation free of charge. Finally, untie partner and kids. Job done.
rb62 like you after going round in ever decreasing circles I changed from the Agilis CP tyres to the Maxiss Vansmart AL2 all season tyre and I am delighted with them. Ride is better, fuel economy when I am driving as good as before.
The tyre also did well in a promobile test.
