Tyre Pressures
Worcestershire
Burstner Elegance
Ok, I know this is a bit of a funny subject but I'll ask anyway. When I bought my Elegance a couple of months ago the chap I bought it off said that he was running all the tyres at 85psi. At the time I thought it was a bit high but didn't question him because I've not had one before and didn't know any different. After a fed trips around I'm feeling that they are a tad hard. There's a fair bit of "crashing" over bumps / potholes etc....
My mate has an Autotrail Chieftain and runs 75 in the front and 65 in the four rears. He reckons his is a lot softer and nicer to drive.
So, what are people running their tag axles at? I'm guessing Argos and Elegance models would be comparable?
There are many threads on this subject. In essence to obtain the correct tyre pressures for your motorhome, take it to a public weighbridge, fully loaded and establish weight on each set of axles. Then go to tyre manufacturer and provide tyre detail and axle weights. You will be given the correct tyre pressures.
As above again, if you choose Continental tyres you get the brilliant technical data guide that covers all sizes, weights, including tag or single rear axle If you choose Michelin they will give the standard answer of 80 rear 65 front. Either way, getting weighed is the only way to work out what is right for your individual Motorhome.
Some do have the view that they should be set at maximum, though I don't agree with this.
Don't know about other makes of tyre.
Michelin’s recommended pressures for mine were:
Front 54psi
Rears 72psi
Ian
Is there a database of where weighbridges are, what they can weigh ( i.e. Single axles or only total weight), what they charge? If not could we each take our local county and list them?
