PeteT1201
Hopefully you are not fed up with my pestering!!
What aerial set up do you guys recommend?
Do you plug this directly into the back of the tv through a window.August DTA240 little magmount aerial.
It will be the best 10 quid you ever spend. Forget all the expensive contraptions above
Just plug ours directly into the TV, the coax comes in through the door and the aerial is on the roof above the door.Do you plug this directly into the back of the tv through a window.
I have an external Ariel socket so I guess I plug the August DTA tv Ariel plugged into this and then have the tv and it’s Ariel still plugged into the wall plate Ariel socket inside to complete the circuit.
I’m guessing that I then get a boosted DTA signal because the external Ariel must be on the same circuit on a splitter as the inside plug which had its own vision plus booster box.
I suspect although it works amazingly well, the build quality is not there to be left out in the rain, and will soon corrode and stop working.ElddisNotElvis Richard n Ann nomadic John Barrett Wh05apk
Is there any reason the August 240 or 250 could not be permanently placed on top ? I m thinking gluing a tin base to the roof and ensuring aerial is stuck to tin base but using magnet as well to enhance signal.
At that price just buy two then you have a replacement ready!I suspect although it works amazingly well, the build quality is not there to be left out in the rain, and will soon corrode and stop working.
What about bonding a piece of ferritic stainless steel to the roof...ElddisNotElvis Richard n Ann nomadic John Barrett Wh05apk
Good idea. 500x500mm is a little excessive!What about bonding a piece of ferritic stainless steel to the roof...
500x500mm £17.12
Polished Stainless Steel Magnetic Sheet Plate 0.9mm to 2.5mm Thickness UK Made | eBay
SS430 is a magnetic stainless steel grade. SS430 SHEET. 0.7mm SS430 Polished. AVAILABLE SS430 SHEET SIZES. 0.9mm SS430 Polished. 1mm SS430 Polished. 1.5mm SS430 Polished. 2.5mm SS430 Polished.www.ebay.co.uk
Then you can stick it on magnetically just when needed![]()
Currently playing with a couple of ideas.What about bonding a piece of ferritic stainless steel to the roof...
500x500mm £17.12
Certainly would I reckon. Might well do the same when my van eventually arrives.
I ve bought too many and cant see a reason as to why i would want the excessCertainly would I reckon. Might well do the same when my van eventually arrives.
Other vans aren't always an indication of which way and polarity to aim for.just look at local houses or other motorhomes to see which setting you need.
Hopefully the correct magnetic pole will be facing upwards for the aerial magnetI ve bought too many and cant see a reason as to why i would want the excess
I ll let you know how it works and you can owe me a beer if we ever meet.
Give me a shout in about a week
If it dont work then i ll park the other way roundHopefully the correct magnetic pole will be facing upwards for the aerial magnet![]()
Good point.Other vans aren't always an indication of which way and polarity to aim for.
Many attempt to find a signal but eventually think "sod it, I'll read a book" and leave the aerial where it last pointed.
House aerials of course aren't adjustable once fitted so will always point the right way
