Thanks for the confirmation Ed !I think you have the 'changing gas bottle' error. Very annoying. If you start the Truma Combi on gas without switching the gas bottle on/or if the bottle is very low/or it runs out it will shout error 517.
Similar happens if you switch it to electric without being plugged in......
Unlike the fridges which just cope with it and sort themselves out....... Thank you, Truma.
Thanks for that, I'll make a note of it in case the fault comes backThe 517 code is gas supply interrupted. It could be the regulator. The heater uses a lot more gas than the fridge or cooker. A failing regulator will show a fault first on the Truma boiler and the continued working of other devices does not guarantee it is working properly.
Not had this problem myself but have read several posts about regulators gumming up and failing to supply sufficient gas for heating but still working on other appliances.
Me too. Poor design, isn't it?We’ve had the low gas bottle issue, and needed to do a physical reset on the boiler as it wouldn’t restart with a fresh bottle. Extremely annoying.
A complex 6kW gas heater the size of a small microwave oven needs a few safety devices. The longer cut out only happens if you try to restart a few times without resolving the problem. Can be annoying but I would rather have the safety systems.Me too. Poor design, isn't it?
Why can't Truma revert to the old controls or use a system like Dometic fridges which just work when you reconnect the supply????
