- Oct 15, 2007
- 3,277
- 6,294
- VW T6.1Kombi day Van
- Since 2004
I intend do do both Jim.Looks very nice John,when it's polished up it will look really nice
Is it for looking at or are you going to chance riding it?
John.
Like those rear set footrests, the standard ones are really too far forward.That really is a nice looking bike. Love the colour.
Same model as mine 1975. Mine is UK spec. I've owned it since 1998. I've customised it to my taste. The tank is off a TR6 (I like the shape) norton bars a bit wider/flatter than the standard "western" bars, rearset footrests, T160 kick start, (doesn't dig into my leg) pee shooters,
Side panels are T120 look alike (rare or fair? spares) MK2 Amal carbs, no air filters. The engine has been tuned, high lift cams and various other mods.
It goes really well, with no major oil leaks.
One of the easiest modifications I did was to drill the front disc rotor (similar to modern bikes) it transformed the brake efficiency.
Please ask if you need any info/help.
Frank
Thats my issue, I'm so used to LH gearchange I would have wrecked the gearbox by the time I got to the end of the roadLH gear change![]()
You re right of course, I switch easily enough from RHD to LHD I could probably do the same with Gearchanges, as you say it was standard question even in the later seventies when my motorcycling started. so I must have done it then. I even remember testing a T140v back then.I have to say, back in the 60's & 70's if you were borrowing a bike you would ask the owner "what's the gears?"
The answers could be:
1 up 2 down
1 up 3 down
1 up 4 down
1 down 2 up
1 down 3 up
1 down 4 up
3 straight down
4 straight down
5 straight down
3 up
4 up
5 up
The gearshift could be on the Left or the Right
I was young & bright, it never bothered me in the slightest and I just rode/thrashed it
Then the Americans said: The gear shift had to be on the left with a pattern of down into first, neutral, up for 2,3,4,(5),(6) - 1 down 5 up on modern bikes
Whilst the UK and EU has never passed such regulations, the American regulation was accepted as an international standard by most manufacturers
The only real problems it caused was in road racing
In particular, accelerating whilst cranked over, there was insufficient ground clearance to get your foot under the gear shift pedal in order to change up
As a result, most racers would run reverse shift - commonly called 'Race Shift' or 'GPshift' (1 up 5 down for modern bikes)
I have always ran Race Shift on all my bikes since the race days as I prefer it, when I borrow or test ride another bike, I can switch my brain to work standard shift easily
I rarely get to ride right hand shift bikes these day, on the odd occasion I do, I really have to take it very steady and think about every gear change and braking (brake on the left). After about 10 miles it comes naturally.
I think adapting from left to right is probably simpler as in many cases you are riding low revving and comparatively slow accelerating bikes with plenty of time to think about the change....
I have a number of mates who have loads of bikes, they tend to put a sticker with the gearshift pattern and side near the instruments - LD would indicate 1st gear is down and a left shift, RU would be 1st gear up and right shift - you get the idea
That said, if you have a desire for a certain bike with a right shift, it is not that difficult to change it over to left shift - there are quite a few racers, who due to injury, run right shift on modern bikes (Ian Hutchinson being one of them)
Life's too short to let the position of a gear shift stop you from having your dream bike![]()
Very nice. I just love the optimistic speedo. My old Trophy with its 43 HP struggled to get over 110!Here are some pictures of the Bonnie now I’ve got it home, couple of jobs to be done as one of the fork seals has popped off it’s groove in the fork leg, going to fit a new battery and change the oils.
I eventualy got it kicked up yesterday afternoon but today right thigh muscles ache off and I haven’t the weight ( 11st 10lbs ) to swing the kickstart plus the oil is thick with the extreme cold.
John.
View attachment 464988View attachment 464989View attachment 464990View attachment 464991View attachment 464992
Looks a very nice example, though I’d say a 76 model rather than 75, is the second letter of the engine number a P? The chrome looks very good. I’ve been doing mine the last couple of days, fitted fuel lines, balanced the carbs (manually), put cone filters on, black/silver number plate, leather tool bag, tightened a few nuts, kicked it over with the plugs out to ensure it’s pumping oil around and fitted the battery. It’s really ready to start but I think I’ve peaked too early with this weather as I really want to get out on it.Here are some pictures of the Bonnie now I’ve got it home, couple of jobs to be done as one of the fork seals has popped off it’s groove in the fork leg, going to fit a new battery and change the oils.
John.
is the mileage genuine?Here are some pictures of the Bonnie now I’ve got it home, couple of jobs to be done as one of the fork seals has popped off it’s groove in the fork leg, going to fit a new battery and change the oils.
John.
No , it was a friend who raced it years ago , I’ve owned it for 18yearsNorton Feather bad, the best frame ever made. Do you or have you raced it ?
I started my flying career on a Suzuki 250 with the aid of a Reliant Robin but it was short lived I only managed about fifty feet and the landing was very amateur, never tried it sinceOR
There are old pilots and there are bold pilots but there are no old, bold pilots.............I’m an old, bald pilot![]()
Similar tale. I started my flying career on/off a FS1E. Cleared a Mk 4 Cortina estate. I don’t think that was bad for a first attempt.I started my flying career on a Suzuki 250 with the aid of a Reliant Robin but it was short lived I only managed about fifty feet and the landing was very amateur, never tried it since![]()
CB200 for me, the insurance limits then were 225 and 350 until the 350LC came out that was............I started my flying career on a Suzuki 250 with the aid of a Reliant Robin but it was short lived I only managed about fifty feet and the landing was very amateur, never tried it since![]()
I started mine in October 1967 250 Royal Enfield Crusader Sports and an old bloke in a Austin something or other, he pulled out of a side street on to the main road whilst he was on the wrong side I came around the bend and hit him head on, 3 months on traction and left leg now shorter than the other.
I failed my flying lesson.
John.
What a coincidence, I’ve just got back from my first ride around the block on my newly rebuilt T140, a few little noises to investigate, clutch to adjust but other than that it all went very well, only did about two or three miles to see what it went like. Not really supposed to be out.To day a new V5 with registration number arrived from DVLA, I’ve insured the Bonnie with Hegarty Classic insurance with RAC breakdown for a total of £138.I’ve just got to give it an oil change plus a couple of small jobs then I will have my first ride on the bike.
John.
Possibly just a bit before your time 48 years ago ,I was a member of the Hamilton road hogs ,my friend had a triton and all our group loved it then .My self I only had a Norton commando 750 high rider ,used to park it up your way we’re I worked at John McGowans.Sad day , I sold my Triton today , after 18 years of ownership , with other commitments I just can’t see me having time to Finnish & use it , oh well
