Travel with water in tanks.
Elddis 194
Hi all,
Can anyone confirm as to wether it is safe to travel with tank full of half full? I'm wondering if the tank is constructed to withstand the forces and the weight of all that swishing water. Or should I be travelling empty and filling up at sites? It's an Elddis 194 btw.
I have looked at the Elddis website and there is a recommendation not to travel with water, but no reason given as to why. It just seems a bit daft if we're traveling for a few days without using designated sites.
Many thanks.
PVC
1995-2004 & 2017》
Hi all,
Many thanks.
Only thing to stop travelling with full tanks is payload..or lack of it.
The ammount of water is not going to do any damage by swishing around...
Yes in a large ships tanks they have baffles, but nothing to do with possible damage but more to stop instability of vessel.. and the ammount of water we talking about in a moho is not going to be even noticed by passengers..
Jim
Ringleader
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I cannot say without knowing your tank setup. However, I can say, that it's only in the last ten years or so that makers have been mentioning that it's best to travel with just 20L, and that, happily for makers and their P' Poor payloads, coincides with them not having to include full tanks in their MIRO calculations.
I can also tell you that in 35 years I have never left home nor left a campsite without brimming my tank first. (y)
Two on Tour
Elddis Autoquest 175
Since 2010
If we are touring, then we always fill up before we leave home and refill when we can and keep topped up as you never know were you can get your next lot of water from.
If we are going to a site for a few days or a rally where we know there is water than we travel with just enough water to flush the loo and make a cuppa. We are normally vertually empty for the last leg home.
Water takes up payload and would think that's why Elddis say not to travel with a full tank.
PP Bear
Kent, UK
Auto Trail Dakota SE
Tis all about the payload. They don’t make a special tank for Elddis, but about the next to zero payload they’ve left the owners to use.
Lots of us fill them up, brimming, plus I carry extra on top of that too, after all you never know when the zombie apocalypse will come and you need to be prepared 🧟‍♂️ 🧟‍♀️ 🧟
Upvote 1
Elddis 194
Thank you.
Todmorden
Van conversion
FUNSTER in a PVC
Tank should be fine but it is the fittings holding the tank to the underside of your van that you have to think about, I think Elddis have had issues with tanks pulling brackets from chassis members. As a rule I try with just enough water to flush and wash cups enroute and then fill up on site or get 5 Litre bottles from Tescos. I always make sure Grey water is either empty as we set off or empty as we travel under rear tyre so not carrying extra weight.
There is no point in carrying loads of water which in turn could reduce MPG.
meanders
Funster - Life Member
Ipswich, Suffolk
Eura Mobil Terrestra
Since 2004
Just remember that a 100lts of water weighs 100kg. If you only have 500Kg payload, two people at 70kg each, plus a couple of gas cylinders doesn't leave much for anything else. However I rarely travel with no water, and if I expect water to be difficult at the far end, will take on half a tank at home in the knowledge that we can do a couple of days. Certainly no problem with the tanks though. They are pretty robust.
Upvote 1
PP Bear
Kent, UK
I fail miserably with this calculations, I’m around 110kgs of pure lean muscle and SWMBO is around 80-90, so we’ve failed there and many can only dream of 500kgs 😀
meanders
Ipswich, Suffolk
Since 2004
I am OK with full tank and diesel, us and the cats and electric bike. Only did the weighbridge once with this van and we were just over 150kg light. Daren't weigh it when carrying all the sound and lighting gear as well though. Fortunately I can take the lighter weight gear. My original three 6 way at 15a dimmer packs are 27kg each. The new ones are under 2.5kg but are only 4 channel. at 5a! The technology has improved massively but it doesn't have the capacity to run my 1500W and 2kW spots so I have to keep the old ones. Same with the sound gear. My old speakers are many times the weight of the newer ones.
Mobilvetta Euroyacht
1996, then break 'til 2011
Once lived on a small boat, having to fill the water tank from 20L containers I've learned to use water sparingly - even at home but I usually carry full tanks of water in the van.
My tanks have large inspection lids - they have to be tight!
PeterCarole29
Colchester
Renault Master Fleetwood
20 years
Thats interesting about useing your tank water for tea. I have wondered if people do or how many dont
Etrusco CV540 DB
Our van has the 90l grey water tank under the van but the 100l fresh water tank is next to and partly over the right rear wheel arch, so if filled there would be quite a lot of weight relatively high up and on one side which is not great for handling. I have sometimes felt that the van is a bit more understeery on fast right handers than left handers which might be due to this, so we now generally only fill it between 25 and 50 as shown by the half full light flashing even though we have plenty of spare payload. That is sufficient for us as we mainly stay on campsites with full facilities.
MisterB
Essex
Adria 670 SLT
We also use water from the tank for brewing up ......and top up regularly if we know we're going to be wandering around or will have to pay for water .....
I hadn't considered the zombie apocalypse scenario, but it does make sense to include it in any planning for long term travelling along with water being affected by radioactive contaminants or even by some UK water suppliers .... :unsure: :unsure: :LOL:
BikerGraham
Newcastle upon Tyne, UK
Autograph 75-2
camping and caravanning since a kid. New to motorhomes
Always travel with fresh water tank at least half full, preferably full though.
Even going to Spain. Arrive at ferry terminal and have a brew while waiting to load. Same water means no need to worry at al en route.
Use tank water for most things including brewing up and cleaning teeth. But the boss has bottled water for when drinking pure water. Some people are strange I suppose 😳😳😂
Upvote 1
Two on Tour
Since 2010
I installed a water filter, so we take all of our water for drinking and hot drinks direct from a seperate tap from our fresh water tank via the water filter.
It's really nice not having to buy bottled water, cart it around and store it somewhere on the van. (y)
Upvote 1
South Killingholme, Lincolnshire.
Autocruise Gleneagle
I'm a newbie had a wobbly box when adam was a lad
I always have a full tank from my caravan days Van Masters always towed better with a full tank being situated right above the axle so weight was centre of the van
Upvote 1
Greenwich, London, UK
Hymer MLT 570
The Hymer blurb says no more than 25% full when travelling.
I found out the hard way they are correct.
Travelling with a full tank means the bottom of the tank flexes as you go over bumps.
This was enough to disengage the rod between the drain tap and the valve.
Which meant I was unable to drain the tank until I had figured out what was wrong and then using all my contortionist skills managed to fix it.
North West, UK
VW T6.1 Transporter
Never stop learning 😊
Any recommendation for the water filter you fitted, please?
Upvote 2
PVC
1995-2004 & 2017》
Well that tells me only one thing...
Hymer fresh water tanks are:--
"Not Fit For Purpose"
