Trauma water heater (1 Viewer)
Jan 28, 2016
2,756
3,331
Stockport, Cheshire
Bravaria i740 AClass
Am I expecting too much when we heat the water on electric. Gets warm but no red hot like when on gas. Or have i got a problem with boiler.
Simon Meadwell
Jan 28, 2016
2,756
3,331
Stockport, Cheshire
Should it get the water as hot as it does on gas? Im going to try electric again tonight and see how it is tomorrow. When its on gas its almost too hot.
Jun 26, 2018
1,132
6,018
North West
Florium Wincester
Europe & USA since April '21
Ours did the same two days after the warranty ended. It was the elements with ours. Got gradually less hot. 6E truma.
We find putting the heating on actually heats up the water.
Simon Meadwell
Jan 28, 2016
2,756
3,331
Stockport, Cheshire
So had the water on electric 2 all night last night just luke warm this morning. Will try it on gas tonight see if its just the electric side.
Lenny HB
56,526
168,264
On the coast in West Sussex
Carthago Compactline
Which setting are you using on the water?
Eco is a waste of time as it heats to 40° but the thermostat has a large hysteris doesn't switch back on until the water is down to 27° so most of the time you get luke warm water.
On Hot it heats to 60° and maintains it there.
On Boost it heats to 62° then turns off.
Simon Meadwell
Jan 28, 2016
2,756
3,331
Stockport, Cheshire
Its on electric no 2 all night
Apr 27, 2008
11,985
14,410
Eastbourne East Sussex
Hymer low profile
Since 1972
We often use electricity on out 4E in the summer and it's fine. Useless if you want heat as well though. We leave the water heater on 24/7 as cant see the point of repeatedly letting it get cold and having to heat it up again.
Apr 22, 2018
7,322
13,439
Herts.
Adria Coral lowline
I would have thought the more the elements work the shorter their life will be. So when I occasionally use electric, I run it the same as when on gas. Turn it on about 40mins before use. Turn off when I don’t need hot water anymore.
Lenny HB
56,526
168,264
I use the timer for hot water in the morning any other time we boil a kettle. Rarely use EHU so normally on gas.
Mar 9, 2022
433
443
Kent, UK
Bessacarr E412
It depends on your unit. We have two electrical settings (roughly applicable to 4Amps and 8Amps (depends on your source). The electric elements never quite reach the same temperature as the gas ( certainly never as quickly). On all night sounds like at least one of your elements isn’t working. We have an ECO setting on gas that shortens the time and limits the temperature a bit. Note what Lenny HB said about cooling down over time ( but it’s not THAT cold now, is it?Forgive the stupid question - but when you say gas gets the water too hot - you do have a mixer tap to allow cold in - don’t you?
Simon Meadwell
Jan 28, 2016
2,756
3,331
Stockport, Cheshire
Yes we have a mixer tap. Its red hot on gas but you can control it. Thats my question it just doesn’t get anywhere near that heat on electric.
