Trauma gas/elec fire..HELP
irnbru
Glasgow
Benimar 264
11 yrs
Parked up and fire on gas, a few hrs later we heard the gas fire ignitor working. Gas fire came on, went out, did this several times so we assumed the gas was empty.
Just been and swapped bottle, in hindsight it might not have been empty as the fire is doing the same thing. Its as if its not getting the gas. Cooker is working.
Any ideas please.
hi Sandra know nothing about the trauma fire but sounds like the flame sensing device which im sure it has may be playing up and shutting it down then its attempting to relight.. does it switch its self on and off automatically, as you say you heard the ignitor working some time after it was set away...
maybe someone who knows the particular fire will be able to offer a better explanation ..
Hi Andy, weare parked up at our usual Troon spot. The fire has just came on again, about 10 min after I put the outside vent cover on. Probably a coincidence but wondered if it was due to the horizontal rain. Just playing a guessing game here and trying to eliminate what I can. Thx
cant offer a fix, but have you had the MH serviced (habitation) since purchased?
gas appliances not working properly worry me
have you got a carbon monoxide monitor?
sorry you have a problem, sorry I cant help and even more sorry if I sound like I am worrying you
presumably you are not on hook up?
again non technical, but I would have thought the vent you have covered would have been for the fridge not the heater which I would think should vent to the roof
A couple of questions to help us help you, are you using propane or butane? Do you have a bottle mounted regulator or a bulkhead unit? What is the outside temperature?
D.
Not on hook up David. I know the previous owners looked after the MH and had a new regulator fitted. Yes oir detector is workibg, tried it earlier. Thx for your comments.
Strangely enough the fire is operating fine again now.
I know nothing but im somehow guessing it might be the rain.
Oh spoke to soon, playing up again .now
D.
Hi we are using propane.
The fire is coming and going. The pilot light keeps going out.
Could it be sonething so silly as the wind ? We are right on the beach.
Bottle head regulator or bulkhead, sorry but being female I aint got a clue. How can I tell ? Thx
if it really is as simple as the wind / rain you could try turning MH round
Propane is fine, rules out low temperature causing butane not to vapourise. Assuming your "TrUmA fire" is a 3002 type model wind is a possible factor, is it a roof mounted flue or through the floor? Bottle mount regulator sits at the outlet valve of the cylinder, bulkhead reg is mounted on the gas locker wall with a rubber hose from cylinder to it. Nothing to do with being female, you just don't know, this is more normal than you think.
D.
H
Maybe time to check whether you packed your thermals!!
Hot water bottles are in the beds now.:)
Think an early night is coming up as soon as the MH cools down
running the engine is a pretty efficient way to heat up a MH, but it will still cool down quickly again
Its a roof mounted flue. Just going to brave the elements and take a photo .
Too dark for photo but I now know its a bulkhead in more ways than one.
All I achieved was a lump on my head. Bloody flap blew shut on me.LOL
No need for a photo, being roof mounted tells me its a S3002 type heater. It probably needs cleaning out. Spiders like to build nests in the combustion air intakes and cause all sorts of problems. Only this week we had a motorhome in for hab inspection and the fridge would light on gas but after ten seconds or so was popping and spitting flame out of the air hole, turned out to be spiders web in the burner assembly as you can see in the photo.
D.
Concur on the spiders webs.
Mine did exactly as yours is doing now.
Removed fire, strip down, cleared jets, blew all out with compressed air and it's been perfect since.
Thx for all the help.
Will look at the bit to be cleaned in the morning.
In the last few mins the wind has died down and fire is working so possibly been the wind. No harm in cleaning what I know to now clean though.:)
