Trailer brake lights (1 Viewer)
Nov 5, 2017
199
362
Nouvelle Aquitaine France
Profile
Since 1980
The brake lights on my trailer do not work. All other lights work, I have tested the continuity on the trailer all is correct, when i plug the 7 pin socket into the car every light works except the brake lights on the trailer, I have bought new sockets for car and trailer new bulbs still dont work. Reading it may be a fuse I have looked at all the fuses are ok do any of you know where the fuse might be on a Citroen Berlingo multi space 2004. I am at a total loss.
Apr 22, 2018
6,828
12,604
Herts.
Adria Coral lowline
You can quite cheaply by tow socket testers. They test both male and female parts, and is something I always use to test before I test anything else.
I canā€™t see there being an individual fuse just for towbar brake lights. They will be supplied by the same supply as the vehicles brakes, and by a canbus relay live if fitted, but if the relay fuse had gone other lights would be effected.
Jul 29, 2013
9,076
18,717
Salisbury
Hymer B678DL A class
since 2011
I had a similar problem and discovered there were two fuses on the tow bar controller in the vehicle battery box one had blown and I was missing the left hand lightsšŸ˜ŠšŸ‘
We have a small black electronic box sitting on top of the battery.
Chickie
Nov 5, 2017
199
362
Profile
Since 1980
Yes checked the output socket on the car all good. I took my car to a mates house to test his trailer his lights did not work so it must be my car, I even have a spare battery so I connected +& - to socket points all 7 individualy all worked including the brake lights, I have been racking my brains for 4 days now. Having a glass of wine now so try again tomorrow. Thanks for reply's but please keep them coming in I need my trailer.
Oct 10, 2018
2,018
1,143
Bracklesham Bay, West Sussex
PVC
If you do not have a canbus system ,It could be a poor connection at the point that the brake light supply is picked up , or a faulty cable. (allowing some voltage through but not enough amps to power the brake light bulbs) . You could try a separate cable from the brake light power supply at the rear to the trailer socket to check this.
43,396
49,921
If it has a canbus bypass box it could be the brake light relay has failed.
Other than that it can only be a break somewhere in the main loom to socket wiring as the vans brake lights work..
