Tpms (1 Viewer)
Apr 1, 2023
51
90
Chester, UK
Eldiss Autoquest 195
Tents, Folding camper,Hired MoHo, now bought our own.
searched threads to no avail.
Can you disable TPMS. Mine's a Boxer .
Regular warnings about pressure, goes off when I've put some air in . Went to Peugeot to sort flashing mileage( all done) they flagged up whole new system needed, module, sensors etc @£360
Dec 2, 2019
4,180
9,382
South Lincolnshire
Rapido 7065+
Broken most bits now
Some people seem to have had some success by removing the tpms controller and doing a proxy alignment to fool the van into thinking it isn't fitted.
416
1,137
Rugby
Elddis Autoquest 185
Since2012
If fitted after a certain year it is mandatory on mot to have fitted . If you disabled it you may find tester would check and potentially fail.
19,541
31,185
Just looked up IVECO metal or rubber £65+£10 postage from Germany for 4 .Understand why they are known as main stealers now !
Yes you can find them cheaper but the original dealer ones are self learning for the wheel position however that works, Aftermarket have to be reprogrammed and I didn’t need the hassle, mind I only needed two, the problem is the battery is not replaceable so it’s new sensor when it goes flat😮
520
675
Lincolnshire, UK
Peugeot boxer
May be wrong but think they all are,in practice the receiver isn't in the middle of the chassis so knows how far each sensor is away from it and thereby knows which sensor is on each wheel,also don't think many of the later ones have a battery all done by some sort of magical electonikery !
Brian/April
Apr 1, 2023
51
90
Chester, UK
Peugeot listed all parts needed down to a locking nut , so maybe not such a bad price. After talking to a local tyre fitter though he pointed out that front tyres were not camper tyres ( these fitted by dealer as two replacements were needed for sale last year. I knew to check age but not camper or van). So again in a quandary ,,,if new system goes on can I specify what pressure to set warnings for.....Can I set different pressure front to back...Got till June for mot.
520
675
Lincolnshire, UK
Peugeot boxer
So it seems you are accepting that 4 sensors and controller All stopped working at the same time ? And accepting that main dealer price is fair ? Go to an independent tyre company get price for new tyres and sensors,if that shows new sensors give correct readings all good if not control unit likely u/S other two sensors probably ok.
Any decent tyre firm will be very capable of dealing with Tpms talk to them
Brian/April
Apr 1, 2023
51
90
Chester, UK
Sounds like good advice, I don't necessarily accept what dealer says I agree it's quite a coincedence multiple failure I'll look into costs from tyre specialists.
