Towbar electrics (1 Viewer)
Feb 22, 2023
55
17
Autotrail navajo
Hi we have a autotrail frontier navajo.
How can I access the rear lights to wire a towbar please?
Thank you.
Jul 29, 2013
9,076
18,632
Salisbury
Hymer B678DL A class
since 2011
if it’s a canbus system on your van it will need a special control box that is connected to the loom🤔
B
Feb 22, 2023
55
17
Autotrail navajo
How can I find this out?
Sep 9, 2019
873
1,926
Runcorn
Autotrail Apache 632
Since Sept 2019
Little Bovey do you also go by the moniker Mr. T?
Cheers!
Russ
Aug 9, 2020
7
9
Carthago A class
Since 2008
Fiat Ducato 2010 2.5 td
You’ll need a bypass relay. Wiring runs in the space between the seats, about a foot to the rear of the battery box. Use a multi meter to identify which wire is which and connect to the bypass relay. Then run 7 core trailer cable from bypass to tow bar. Simples!!
