Totalcool 12v cooling system (1 Viewer)
May 4, 2015
1,242
1,637
North Yorkshire
since 2000
Has anyone bought one or seen one working. Reading the advert it sounds like a good idea, especially as it’s lightweight and can be used in the house as well as the MH.
Mar 23, 2012
9,564
32,185
sleights
c class
Look very expensive to me for a small fan with a bit of wet sponge in it!!!! Also the evaprated water is going into the atmsphere must make it a bit damp. You can buy home ones for a lot less Broken Link Removed not the same thing as A/C
Jan 19, 2014
9,395
24,793
Derbyshire
Elddis Accordo 105
since 2014
This?
You can buy a portable AC system for that money (not that they're very good).
You would be very disappointed in an evaporative cooler, it's just a fan and some water evaporating - very slowly.
JFD
Apr 9, 2015
392
238
Crawley Down, West Sussex, UK
Pilote Aventura G730
since 2014!
Have a look on Amazon - seems you can very similar items for around £30, like this
Rivadal Portable Air Conditioner Fan Evaporative Air Circulator Cooler Humidifier
For some reason the link would not paste correctly, so you will need to look up the item on Amazon!!!
Oct 7, 2011
351
388
hereford
Hymer A class
since 1980
Evaporative coolers only work in a very low humidity environment.
We used large ones when living in Riyadh and they were very good , not only cooling the air but giving humidity too, they were called desert coolers, says it all in the name.
I've tried one here at home and it's useless.
109
1,446
San Antonio Tlayacapan, Mexico
2023 LTV Unity TB
Here in Mexico they are called swamp coolers. We use two large ones to cool our 120 seat community theatre. They are mounted outside and are centrally ducted. They have constant waterflow (recirculated) over the cooling medium. At the time of year when we need them, humidity is low so they do an excellent job. Capital and running costs significantly lower than air conditioners. But for a motorhome, I'd guess there are better systems than evaporative coolers.
