Two on Tour
- Sep 16, 2016
- 10,577
- 53,435
- Elddis Autoquest 175
- Since 2010
We were booked in to the Stratford Campervan Show and it was going to be handy that our route there would take us past a Morrison fuel station which meant we could fill up our underslung LPG tank which was getting a tad low.
With Stratford cancelled, we booked in to the New Forest campsite thanks to the heads up from Wombles, but alas no LPG stations on route there without a detour.
I have a Gaslow reserve cylinder connection hose and a full Calor 6Kg cylinder, but no real space to store Calor 6Kg cylinder in our van, so I thought I would give it a go to transfer what I could out of the Calor 6Kg cylinder into our underslung tank.
Knowing the capacity of our underslung tank and how much gas was in it, I knew it would take at least 11Kg of gas before getting near to the 80% limit.
I weighed the Calor cylinder, then I left the Calor cylinder in the sun to heat up for an hour, connected the hose to the Calor cylinder and the underslung tank fill point, turned the Calor cylinder upside down and on a set of steps to get it higher than the underslung tank, opened the valve on the Calor cylinder and immediately the hose started to vibrate and pulse along with a lot of gurgling noises.
I kept an eye on the proceeding and after about ten minutes things started to quieten down until all went silent. I shut off the Calor cylinder, gentle release the pressure left in the hose and checked the underslung tank level on the Mopeka tank level app and bingo 61% in the tank now. I re-weighed the Calor cylinder and found that 5 of the 6 kilos has been transferred. I now know that I can use this method as a get out of jail free if we get caught short of gas in the future.
Please note that I can accurately measure the gas level in our underslung tank with the Mopeka sensor and app, so I was happy that I would not exceed the 80% in our tank and I would not recommend anybody trying to do the same as I did unless you too can accurately measure the gas levels in your tank.
