- Mar 5, 2011
- 670
- 1,071
- A
- Since 2008
Unless you have bought other maps such as USA or Australasia etc the only map on your GO500 will be Western Europe and if you want to download the Full Map with 3D buildings then you will have to install a Micro SD card, max 32GB although 16gb will be more than enough and the map is installed to that. I suspect that the Non 3D buildings will become to big for the Internal memory in the not to distant future.
Why do you want to buy the UK map with or without 3D buildings unless you are think that as it will be smaller it will update quicker. The UK map will provide you with no more benefits. As far as I know you could buy the UK map and install it on the Internal memory provided that you have deleted the Western European Map first. Once you have then installed the UK map internally you could then if you want install the West Euro map onto the extra memory the 2 maps would then appear in the change map option other than the Europe 995.8490 you should have now as it is logged to your account.
You should not need to do a Factory Rest unless you have an operating problem. A Soft Reset should be enough following updates. Doing the factory reset means you then have to wait for the unit to reload all the POI files and Routes you had on it from the TT server either by the inbuilt Sim or when connected to your computer and you have ensured your unit has logged into your TT Account.
Hope you are up and running okay now.
Doug
Doug
