- Oct 13, 2023
- 39
- 32
- Autosleeper Warwick
That would depend on the construction of the van, in ours all the lockers are spaced off the wall, there are vents to allow air circulation between the hab area and the double floor & garage so not a problem.IMO the ventilation is not circulating therefore the damp can settle in pockets not reached by the direct vent, just saying.
i use the crystal water absorber bags get them on amazonThis morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
Bought our beldray version from Robert Dyas for £19.99, curved windscreeen presents a minor challenge but effective reliable device. Excellent battery life in the cupboard. Seems much better value than karcher£34.99 in Lidls from Sunday 19th November.
Hi Gavin,This morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
Kitty litter granules in old socks…. Works for me!This morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
The opposite doesn't seem to reliably happen as evidenced by condensation which stays on the inside of windscreens even as things dry out outside?
This is why MHome fun, is so fun. Every Everyone offers all their advice and your left pulling your hair out wondering which way to go.There is absolutely no point in putting dehumidifiers, salt, or rice in a Motorhome or caravan.
Motorhomes & caravans have perminant ventilation, what's the point of trying to dry out the atmosphere.
Heat and ventilation.... Just that or stop breathing in your sleep!This morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
Oh come on where is the fun in that........many of us also like to boil the oceanThere is absolutely no point in putting dehumidifiers, salt, or rice in a Motorhome or caravan.
Why then condensation on the outside of our double glazing when toasty inside? (Rhetorical)For condensation to occur you need two things:
The only way that you’d get condensation on the outside of the window would be if you were able to refrigerate the interior of the MH to such an extent that the windscreen ended up cooler than the external ambient air temperature.
- moisture in the air
- a cold surface onto which the moisture can condense
This is what’s happening when you get condensation on the outside of (around the door seals typically) a fridge/freezer.
Ian
Looks to me like it's reducing the humidity from 62 to 58% but as soon as it's off the humidity rises again. I'm not sure if that's a big enough effect to actually acheive much.I recently bought a small compressor dehumidifier for the shed, it's compact and is only about 100w
It really works keeping the condensation off the bikes, you can see it switching on and off on the graph..
I've sealed the shed up as much as possible, as I don't want to dehumidify Derbyshire with the van it will only lower the humidity to the same level as outside unless you can close all the vents and gas drop outs
Yeah, actually I should have said that graph is from a little Bluetooth gadget in the shed that is probably not very accurate but shows the up down trend. The dehumidifier's tank does need emptying about every week though so it works.Looks to me like it's reducing the humidity from 62 to 58% but as soon as it's off the humidity rises again. I'm not sure if that's a big enough effect to actually acheive much.
Irrelevant to OP as the ONLY cure is heat and fresh air..... Unless you really don't breath in your sleep!It doesnt say on your profile which van you have are the windows single or double glazed?
But does it? It works in getting moisture out of the air in the shed but is there a reduction in the moisture enough to reduce any effect and is the moisture just being replaced constantly from equalising with the atmosphere outside the shed.Yeah, actually I should have said that graph is from a little Bluetooth gadget in the shed that is probably not very accurate but shows the up down trend. The dehumidifier's tank does need emptying about every week though so it works.
If it's any help, it's dry today here in Surrey.But does it? It works in getting moisture out of the air in the shed but is there a reduction in the moisture enough to reduce any effect and is the moisture just being replaced constantly from equalising with the atmosphere outside the shed.
As I said, I've sealed the shed up as much as possible, it's not air tight of course but the new air entering is kept to a minimum. The dehumidifier is 100w so 10 times more economical than a heater.But does it? It works in getting moisture out of the air in the shed but is there a reduction in the moisture enough to reduce any effect and is the moisture just being replaced constantly from equalising with the atmosphere outside the shed.
Which, as long as no one is breathing and there are no water leaks is not a problem.Perhaps a dealer might be able to advise as to how they winterise the fleets of vans on their forecourts?
I'd be doubtful if it involved anything other than perhaps opening a door on a dry sunny day, and even that's unlikely.
Mike.
Are we discussing the same topic? An occupied motorhome will almost certainly need proactive measures, but an unoccupied motorhome shouldn't need any special measures, the essential requirements have been built in at the construction phase, roof vents, spaces behind cupboards, et al.Which, as long as no one is breathing and there are no water leaks is not a problem.
YesAre we discussing the same topic? An occupied motorhome will almost certainly need proactive measures, but an unoccupied motorhome shouldn't need any special measures, the essential requirements have been built in at the construction phase, roof vents, spaces behind cupboards, et al.
Mike.
You would hope so. Certainly a good idea to remove cushions etc.Are we discussing the same topic? An occupied motorhome will almost certainly need proactive measures, but an unoccupied motorhome shouldn't need any special measures, the essential requirements have been built in at the construction phase, roof vents, spaces behind cupboards, et al.
Mike.
