- Oct 13, 2023
- 39
- 32
- Autosleeper Warwick
Ventilation. Some of those crystal water absorbers. ?This morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
Thanks, what device is this?I keep mind locked tight, including all windows, then use this. Lots poo poo it, but had it now for 11 years and it’s brilliant. Some quote that in the last million years, they haven’t had a problem, but you have, so it’s my recommendation.
Wonder what an insurance company would say if they knew windows were left open, just a bit, but enough for anyone to get a long screwdriver or crowbar in, force it open and enter. Yep, they could do that with the windows tightly locked, but noisy, damaging and I don’t think any thief will want to drive with smashed windows.
Worth every penny and they also come scented, so van pongs nice too
Karcher window vac every time - we use ours to remove the condensation from our windows and also to dry our shower works brilliantly.This morning my campervan had loads of condensation in the windows. I'm sure there must be loads of ways of managing this. I don't store it with hook up so I can't run a dehumidifier. What else can I do?
There is your answer warm are holds more moisture than cold air. Turn the heating off and air it well before shutting it up.I have been in the van during the day as we are renovating it and painting it. The heating has been on.
Also if they paint with a water based paint the warm air will absorb a lot of the moisture as the paint dries. When the windows cool it's going to be deposited there.There is your answer warm are holds more moisture than cold air. Turn the heating off and air it well before shutting it up.
£34.99 in Lidls from Sunday 19th November.Karcher window vac every time - we use ours to remove the condensation from our windows and also to dry our shower works brilliantly.
Here we are….Thanks, what device is this?
That may be why. Was the heating on when you were in it and off after you left?I have been in the van during the day as we are renovating it and painting it. The heating has been on.
But is that because of the salt or despite it!I can't speak for the MH as I use mine throughout the winter, however, in my static caravan I used to use two washing up bowls filled with water softener salt. £6 a bag.
Never had a problem with condensation, damp or mould.
We have only had a caravan and MH for roughly 20 years and never had damp but never used any salt!I've used salt in large bowls for over 40 years in the mh and in mobile homes and never had damp problems
You will get condensation this time of year if your renovating the motorhome. I'm sure once your finished and paint is dry etc condensation will record. We always put a couple of dehumidifier bags in van summer and winter to collect any excess water in air.I have been in the van during the day as we are renovating it and painting it. The heating has been on.
Interesting point. I wonder if, in the absence of active ventilation, drying out the interior simply results in gas exchange through vents so that humidity equalises as fast as it dries?There is absolutely no point in putting dehumidifiers, salt, or rice in a Motorhome or caravan.
Motorhomes & caravans have perminant ventilation, what's the point of trying to dry out the atmosphere.
It will given time but under normal circumstances you won't get any condensation.The opposite doesn't seem to reliably happen as evidenced by condensation which stays on the inside of windscreens even as things dry out outside?
The salty absorbs all the moisture from the interior, so dont leave the loo full with the seat upBut is that because of the salt or despite it!
IMO the ventilation is not circulating therefore the damp can settle in pockets not reached by the direct vent, just saying.There is absolutely no point in putting dehumidifiers, salt, or rice in a Motorhome or caravan.
Motorhomes & caravans have permanent ventilation, what's the point of trying to dry out the atmosphere.
