If that occurred by any serious amount the teeth on the belt would no longer fit the sprockets.Good idea in theory, but the old belt will have stretched VERY slightly so THE teeth MAY NOT line up with the new belt.
Dont know but all engines need the similar locking procedure - access may or may not be difficult my A class is as easy as a van ie not that restricted but it is 18yrs oldJust done my 2006 JTD all be it on an Autotrail.
2 man job to undo the dif bolt if someone’s available. On mine there’s a clear section cut out at the bottom of the gearbox and I easily inserted a screwdriver that locked the flywheel, while someone else loosened the nut.
Refit of the dif bolt was the same procedure.
No requirement to lock the cam shaft either and the timing marks were clearly visible.
Can’t imagine how tight it must be on an A class. That'll teach you, should have got a real motorhome and none of that fancy A class rubbish![]()
The Inner wings On an A class are normally the same as a panel van so shouldn’t make any difference to changing the cam beltDont know but all engines need the similar locking procedure - access may or may not be difficult my A class is as easy as a van ie not that restricted but it is 18yrs old
Never heard of any such a thing in all my years.Pretty sure you also need a new idler pulley bolt if it's not in a kit. I was told it's a stretch bolt and if you reuse it's not unknown for them to break. Someone else may know more or comment?
It baffled me too when I was searching for a good quality belt.My two Penny's worth ,don't go for a cheepy belt either.
Gates or similar is recommended (fiat forum) did mine last year had done 74000klms but had stood around for a good while choice of 2 belts from memory 154 teeth or 153 teeth (?)
Water pump does need a change 2.5tdi fiat 1998.
The teeth would not stretch as the material is at least twice as thick as the flat section of belt between teeth.If that occurred by any serious amount the teeth on the belt would no longer fit the sprockets.
A stretch bolt is normally designed to pull machined mated surfaces together, such a cylinder head.
No such requirement on the crank bolt, it's flippin huge in terms of a stretch bolt and 200Nm isn't stretching it at all![]()
Never heard of any such a thing in all my yearsUOTE]
Are you an engineer? If you read what I posted I referred to the idler pulley bolt not the crankshaft bolt. There are lots of stretch bolts that could possibly be safely reused but the idler pulley one is not one I personally would risk. I am in a Fiat workshop today and will ask the question.Never heard of any such a thing in all my years.
And I'll have to agree with you - I missed the fact that it's a 2004 van.
As mentioned I did my cam and auxiliary belts last Saturday.Re: Idler pulley bolt - Can you ask if that applies to all the Ducato engines (I have a 2.8 JTD)?
https://www.ebay.co.uk/itm/Gates-K0...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649thank you all for your replys i have since found out that the water pump on my MH is nut part of the timing belt as was mentioned on here but i also found out that you get 2 idler pulleys 1 a steel and 2 what looks like a nylon one with a £60:00 price differnce .
2006 and now on 34300 miles.pp Bear what age and milage is your MH if i can ask
I've had it 7 years (August 2012) and this is the second cam belt change, as I couldn't verify if it had been changed before I brought it.
I had no workshop facilities when it needed changing the first time (2013) so trusted it to a garage. Some months later the bolt that holds the 2 parts to the top mounting sheared and the engine dropped quite some distance and impacted on the driveshaft, splitting the gaiter, but luckily no other damage. Mind you, that was enough as the gaiters are a pain to change. The garage had told me at the time of them doing the belt, that they had to re-tap a mounting bolt thread, so I'm guessing that they might not have done the job correctly, but was months later when the bolt sheared.
My advice is either change the entire mounting, or remove the 6 bolts holding the mounting and remove the entire thing, so as not to need to release the single mounting bolt.
A small 2 ton trolley jack and a block of wood supported the engine and was then gently lowered giving much improved access to both the alternator tensioner and cam belt.
Hope I'm not teaching you to suck eggs, but remember to loosen all the required bolts on the alternator so as to not put the tensioner bracket under any undue stress and then pinch them back up again after refitting a new auxiliary belt.
There are some YouTube videos of the 2.8JTD belt being changed, not in English unfortunately, but gives a good insight into the system and pulleys and the tensioner.
I reviewed the Gates website for the part number of the belt kit and then searched for the part required on fleabay.PP Bear can you tell me where you got the parts no for your kit as I found a kit quite a lot cheaper which has a different part no or is your van different year to mine
Best price T,B, kit 31473921 supposed to be gates kit as well ? £43:83
2 bearings and a belt .
