Thank you, my awning does not have any pitch control screws, and I need to close the door when I put the awning out, otherwise it catches it. The awning does drop down a lot when wound out, so I wonder if this would help?Not sure if this would help but you can adjust the pitch of the awning when it is opened. However I don't think this would affect the angle of the lip when closed.
Here's the pitch instructions anyway, it involves adding/removing spacers.
What model of Omnistor is it ?Thank you, my awning does not have any pitch control screws, and I need to close the door when I put the awning out, otherwise it catches it. The awning does drop down a lot when wound out, so I wonder if this would help?
It is a 6300 4m long.What model of Omnistor is it ?
In which case, the pitch control is available. You just need the screws/washers. I did read of someone who got in touch with Thule and they sent some out free of charge.It is a 6300 4m long.
They appear to be M 8 Allen Screws and washers, does anyone know how long they are?In which case, the pitch control is available. You just need the screws/washers. I did read of someone who got in touch with Thule and they sent some out free of charge.
I helped fit a 6300 4m to a mate's van, we had to put the pitch control on maximum to stop the awning hitting the sliding door if it was open. Sounds similar to your experience...
Thanks, I will give that a go. The winding mechanism feels to be in good working order, as there is no play, and does in wind in and out without a problem.Try winding it out fully. Spray some lubricant- preferably silicone but if you’ve only got wd40 it’ll do for quick fix then wind in. I had same a couple of years back whilst away. I think whilst it’s out, wind blows dust and debris in and causes issues when you come to wind in and close the cassette box.
If it continues it could be a worn cog on cassette mechanism. Try Rose Awnings for advice and spares/repairs.
I guess the dealers (or whoever fits the awning) just bins the supplied pitch kit. Or resells as an accessory
£12.49 for 2 screws and washers! Plus postage........I guess the dealers (or whoever fits the awning) just bins the supplied pitch kit. Or resells as an accessory
My Omnistor arrived today, I'll see if the pitch control is in the box and post up the bolt specs if it helps.
Thank you, I had a play around with a couple of mate bolts, and found that 12mm long with 2 washers gave me the right drop. The awning now goes correctly into the cassette box. Prior to installing the screws, the awning dropped down a lot when leaving the cassette box, it now seems to stay at the same height. I would still be interested in the length of the bolts supplied. Apparently you can also adjust the bolt under the right hand cover, but fortunately I did not need to do this.My Omnistor arrived today, I'll see if the pitch control is in the box and post up the bolt specs if it helps.
Thank you. I suppose it also depends on the thickness of the washers, mine are 1.4mm thick, so the length of my bolt going into the awning will be 9.2mm. What thickness washers are supplied?The bolt thread length is 16mm and total length including head is 21mm. Thread diameter 8mm.
