Thetford 200cwe Flush Repair (1 Viewer)
43,435
50,316
pappajohn submitted a new resource:
Thetford 200CWE flush repair - Blown fuse in thetford toilet
Thetford 200CWE electric flush toilet.
The flush button is on a removable bezel which is held by two plastic 'posts' and some non setting mastic sealer...prise off carefully with a broad blade screwdriver.
underneath the bezel is a plastic grid held with 4 screws...2 x rear..2 x front...ignore the center ones, they hold the plastic posts.
when removed look to the left, you will see the white filter, follow the pipe down and you will find the pump.
CAREFULLY unclip the pump amd hoses, one...
Read more about this resource...
