davethespark
- Apr 6, 2016
- 20
- 4
- Just looking befor buying
- Did a three week grand tour of Spain
How long do you suggest letting it idle before switching off please?
I have never had my van at 4500 revs... what speed would that be - 90mph?One of the things that make me cringe the most, is those that drive the motorway at high speeds, then pull into a service station and switch straight off. With an engine doing say, 4500rpm, a turbo will be nearer 150,000 rpm and requires to slow down, cool slightly and have fresher oil delivered to the bearings
My ( non indicator using ) hubby has a bad habit of leaving my flipping car in gear. Drives me mad.Had one car which needed the clutch pedal depressing to start.
But in a manual I always start the car with clutch pedal down, having driven a lot of multi user cars where last person has left it in gear...certainly wakes you up as you lurch forward
I think you will find that is the case for nearly all of the US and Canada.Interesting - on some streets in San Francisco you will get a ticket if you don't leave your wheels turned into the kerb.
It is an added precaution to leave the vehicle in gear. My friend has a Defender. He left it parked on a incline and went off and left it. When he came back the Defender had rolled back into another vehicle. The handbrake cable broke.My ( non indicator using ) hubby has a bad habit of leaving my flipping car in gear. Drives me mad.
If I remember rightly it is taught when you take driving lessons as a safety precaution as you say. I don't know if they teach it these days. I just forget that he always does it, forgetting things is get not to be a habit......must be my ageIt is an added precaution to leave the vehicle in gear. My friend has a Defender. He left it parked on a incline and went off and left it. When he came back the Defender had rolled back into another vehicle. The handbrake cable broke.
I think the clutch pedal down was more to do with preventing accidental movement if left in gear rather than being a major help to the starter motor.
The important bit when starting a Diesel engine is to give the glow plugs (when fitted) time to heat up before engaging the starter motor.
Not in first gear.I have never had my van at 4500 revs... what speed would that be - 90mph?
It is
If you have a Comfortmatic the first thing it does is shift into neutral if you haven't already put it there yourself before it cranks the engine. Now whether it also disengages the clutch I don't know but it wouldn't surprise me if it did to reduce drag. It might even be clever enough to decide what to do depending on how cold it is.Ok, so I have an automatic diesel Motorhome. Foot on the brake and turn the key..........so what does this do for the above theories?
It's no problem - the clutch is disengaged as soon as you turn the key and only engages when you drive off or turn off the ignition................. feels wrong with no clutch peddle, robotized manual gearbox.
On ANY Diesel you don't have an Ignition key ...............On a real diesel you don't even have an ignition key
My ride-on lawnmower work crank unless the handbrake is on.
If I take my weight off the seat without the handbrake set the engine cuts out.
It costs pennies to fit an inhibitor switch.
No, it's meant to be a pain in the neck.I think it's meant to stop you mowing your feet
Its compulsory to have one fitted to your brain to race sidecarsIt costs pennies to fit an inhibitor switch
