MANGOFORTH
I've also thought all the windows is a big loss of wall space
It is a pain in the butt to remove and replace with sheet metal. Then it just looks weird. The ceiling height was too low as well.I've also thought all the windows is a big loss of wall space
me? Got rid of it as it proved to be unsuitable for my lifestyle and too many compromises.What did you do with it?
... well go to the loo BEFORE you start, that way you won't have to keep your buttocks squeezed together!Update....
Im still plodding along.
About to cut a peice of ply for the finished wall.... I'm cacking my pants
I remember that, wasn't it an Airstream or something like it?does anyone know what happened to that american bus being converted by a member where the converter went out of business half way through the job. was about 2 years ago
Thats it, what happened?It was Bingo and the bus was a Flixible
I was talking about a hot water storage tank with the built in calorifier.I'll watch it now! How big is big? Currently have squeezed in a 250l tank under the sink. I have space for more underneath but obviously weight dependant
Erm, They are £350-£450 depending on the size and number of coils. Add this to $220 for the diesel heater and point me to a cheaper hot water source pleaseCalorifiers arent cheap , other than saving from regular vehicle movement![]()
Not a balanced flue?... I would be scared of that one?I'm not this far along yet. But what I'd intended was to have this....
Forcali,Bosch Boilers - Forcali 10L Lpg Water Heater Complete With Flue Kit - The Caravan Shop
Forcali 10L Lpg Water Heater Complete With Flue Kit - caravan accessories uk,caravan accessoryshop shurflo pumpswww.thecaravanshop.co.uk
It's really small and only will require the one water tank.
Im guessing it's gas usage will probably be more than the diesel? Thoughts oh knowledgeable ones ?
This is a possible , and capacity depends on your water capacity in my case 400ltrErm, They are £350-£450 depending on the size and number of coils. Add this to $220 for the diesel heater and point me to a cheaper hot water source please
Oh and your solution has to have a least 20 litres capacity![]()
Nice. I hadn't seen that oneThis is a possible , and capacity depends on your water capacity in my case 400ltrhttp://www.rainbow-conversions.co.u...-iwh-15-e-instantaneous-water-heater-lpg.html not much price differential , but weight saver if that's a concern ?
another option ? Dont know if balanced flue but think it must be
Water Heaters - Widney Leisure
www.widney-leisure.co.uk
I remember that thread, a brilliant conversion. Wasn't it a Fexibus or similar?does anyone know what happened to that american bus being converted by a member where the converter went out of business half way through the job. was about 2 years ago
A 1947 Flxible Clipper http://47clipper.blogspot.com/I remember that thread, a brilliant conversion. Wasn't it a Fexibus or similar?
That's the one. Did he ever get it from the converters I wonder?A 1947 Flxible Clipper http://47clipper.blogspot.com/
first line in that link says static caravan not motorhomeI'm not this far along yet. But what I'd intended was to have this....
