Terry's Self Build Relay
I used authentic John Guest speed fit on mine @Terry works fine. The only leaks I get are on the connector that comes out of the top of the Truma Boiler. I don't know why but they seem to fail with great regularity. I now carry a couple of spares just of this connector. Other than that JG speedfit is brilliant and other than one that failed 4 years ago they have been perfect even on the hot water pipes right next to the boiler.
Terry just reading about your leaking hot water, i have a similar problem with my webasto heater, no matter how tight you do up the jubilee clips , there will be the odd weep here and there, i might strip my system and redo with copper as well, or just put a catch tray underneath in case it does it again, btw keep up the good work fella
pete
Morning Karl,we normally use 15 mm speedfit(polly pipe--I have a mate,that works for them and with his discount=cheap:)) and the 15mm to 12 mm reducers that I have to get to the 12 mm bits (pump etc)never have a problem -or any leaks once it's done --The hydronic heater gets things a lot hotter than any of the other heaters hence all the leaks :DNow we have re-done it in copper =Jobs a good un (y)-My mate Kev- plumber - said that on house pipes you are not supposed to use push fit within 1.5 mtrs of the boiler -they are known to fail;)
While I was at Thretford I was talking to Steve/Diane =cockney plumber-,username Mitzy something I think =another self build- anyway he told me to get a thermostatic controlled mixer and put that close to boiler but that did not do anything until a tap was turned on -then it did what was expected and cools the water down -Any way it's working now so like anything else you live and learn --The van although not finished yet is functional so I can use it and in a couple more weeks I get a weekend off from gallivanting around so it should be as near as dam finished and dry :D:D:DJulie is doing the upholstery next week/week after so it's got to be very close to been done (y)She won't give me my seats back until it's all nice ,clean and done :LOL:The van is a learning curve simply because I have filled it with goodies that we have never fitted or used before -That 7 day timer on the heater is more than enough to keep me confused for months -Paul thinks if I get/read some instructions from somewhere I/he Should be able to turn the boiler up and down :LOL:Even the fridge/freezer is one of those stupid self energy choosing things that I don't know how to drive yet :(:D:D:D
Pete do it in the copper and forget about it (y)
terry
Terry, On my first 'Bus' which really was a Bus I used the jubilee clip connectors. I also had leaks everywhere. In addition they are a pain to install. I moved over to speedfit and have been much happier. I did consider copper but decided against it for a number of reasons. It is rigid and in a moving vehicle I could imagine circumstances where the movement of the van would cause problems. Also as a fulltimer I like to be able to repair stuff there and then if something goes wrong. I carry a 2 meter coil of the plastic pipe and a little box of connectors. I also have the JG cutting tool. I can repair a leak in my van in minutes. This just wouldn't be possible with copper.
I do like the work you are doing though (y)
Hi Karl I have only done the first bits in copper (y)I should never have gone with the pipe/clips but it was to get it done so I could use it --I am thinking more along the lines of simply have a couple of weekends working on the van to finish it and then go gallivanting -it may mean missing a meet or two but at least the van will be done/finished and then I can enjoy it (y)rather than making do and it dragging on -Just been out to look and measure up for new doors and straight away looking at doing the overhead cupboards again -even considering altering the beds again all for half inch more room :DWILL KEEP IT ALL UPDATED as and when I do it :)
terry
Update went away for the weekend and gave both heating/hot water a good test along with Fridge/freezer on gas all weekend (y)Came home Sunday afternoon and done very little on van all week but I have put in a odd hour oe two here and there- Removed all the white doors and remade upper cupboard fronts ready/waiting for the new doors to be edged --Made up the drawers again ready for the fronts -Redone the w/top edging strip that has come undone hopefully with a stronger impact adhesive than the last one -finised the sparkle boarding in the loo/shower so only left with a bit at the top and sealing all around so that it's all w/proof once the door is on :LOL:
terry
Still got the white and yes after doing them sq cnrs I would round them off - knock in edging and sq cnrs are simply not good -Thought I may be able to make them OK but once made they look good then next day they have shrunk/moved and look crap =another lesson learned -round cnrs ;):LOL:
Terry did you say your changing back to wood from the white?
I cant say the white does it for me
pete
Hi Pete yes now doing the doors in wood to match carcases -after Johns Thretford meet where almost everyone said wood not white,Then Dave (Snowbird ) came and said what about when you come to sell it ?:) I made them last Thursday and took them to a mates Friday for him to give to his mate and get them edge bound for me (y)so no idea when they will return but if it's not soon I will either get them back or make another set and use the knock in edging :DHoping this weekend will see it 90% finished with just the doors to hang and a couple of bits to finish -that's if I don't change my mind on things again :LOL::D
Another lesson learned stick to what I know works and try new things out on a bench rather than in the van only for me to change it :)
terry
Glad you've made your mind up Terry. But do it for you , your keeping this one remember.........
As for corners , Ralph says that's why ours is so curvy ! It's easier for the knockings!
We are doing wood overhead cupboards and wet room door. Then either brown or cream high gloss in the kitchen area. Can't decide which yet. May even end up wood !
Once Ralph's put the wood overheads doors on this weekend , we'll decide.
Looking forward to having a look at Misterton.
:)Supposed to be Bev (y)It;s not that I mind the wood it was that I wanted to try different things-I have done -some worked while others didn't :DHence changing back to what does work /look right -I could have simply posted all the right things not showing what went wrong but where's the fun in that :)Good for anyone doing there own van they can learn from my mistakes :DYou would think that after doing all the vans we have we would get it right first time and we do mostly ;)Just wanted to try stuff out -got it wrong so do it again -:LOL: Still not sure on layout :(:rolleyes:so you never know it may be for sale :eek:But only after I got/get something for me first -Had enough of Caddy Maxi vans ;)
terry
In a few weeks time we will be starting on Pauls van -Now that should be different :DHe is into modern colours /reds blacks and stuff -more VW camper type - Says he does not want old fuddy duddy old stuff :D What he does not see is us old FDs like old FDs stuff :)His van already looks like a rotting Banana painted from front to back green one half while the other is yellow split length ways -I can fore see a respray coming ;)
terry
He is also quiet partial to pork pies.;);)
Steve
Lol....by the way you do know you can only bribe Max for as long as you have tasty food for him in your hand don't you?;)
Really looking forward to seeing the end result. It looks fantastic already. We were thinking a Luton van with a tail lift might be an idea....but then the cab is separated from the van.....is it possible to knock through? :)
Max was only thinking of your figure Steve :D
terry
It has taken me years of strict training to get this figure, after max eat my pie i had to have 3 kebabs a day for a whole week or would have lost the benefits of all my hard work but with perseverance i just held on.
I think Terry's beef rolls helped as well.
Anything is possible (y)-cutting through is just a case of having the b----- to make the first cut and knowing you can seal between the cab and back :)They make some nice Gown vans and I have seen quite a few nice looking Renault Master luton vans on the road with skirts that go right down, but as yet not dropped on any for sale
terry
terry
Some of that went right over my head Terry! :D
Gown vans? And 'skirts' that go right down....sounds like a ball!
Please explain those two references. The rest I get!
Have you ever seen terry make a sandwich his kitchen skills are outstanding
The bread knife is truly original
Terry, for kitting out something like a tail lift Luton what would be an ball park figure on top of the van price? Just roughly. I know it would depend on quality of materials used, so just a figure to give us an idea? :)
terry
Gown vans= vans that are constructed to carry ball gowns/dresses on hanging rails.
skirts that go right down = the infill side bodywork panels on the outside between wheels & normally have full front rear matcjing bumpers-
You used to get some excellent 'laundry ' vans that picked up washing from hotels/b&b's etc. I converted one in '84. Don't think you get them much these days ?
will PM you early next week
Saturdays update -we started to get more bits done that we left such a sealing the loo shower and basically bits you don't really see much difference in pics -But did get a surprise when Billy /Julie's hubby brought me the passenger seat over making me promise to cover it before we do any work in the van ;):DJust thought I would post the pics before I jump in the bath and shoot over to Goole for a few hours
terry
Those white doors looked like you had chopped up an old house internal door. Am glad you changed em. Now that upholstery I do like.
