Symptoms of clutch slip on Fiat comfortmatic (1 Viewer)
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Hi. Got an odd symptom with my Fiat 3.0L comfort matic gearbox/clutch. I've had a couple of occurrences at around 2000 rpm in 6th where when accelerating relatively gently the revs rise as if the clutch is slipping. Easing off stops it.
Accelerating again doesn't produce the same result.
Engine pulls well under high load on hills etc without any symptoms of clutch slip.
Any thoughts?
Sep 11, 2012
99
65
Cheltenham
Low profile
Just had same problems with mine but it's got a fully manual clutch system
Turned out to be the dual mass fly wheel.
RS_rob
1,010
669
Turnford
over a Year Yay................
DMF - Duel Mass Flywheel.
They are fitted to all modern motors & cannot cope with high power in low gears, they r stupid things that fail earlier than a normal clutch would.
What most likely has happened is youve applied too much power in to high a gear & because the dmf is supposed to eliminate vibration & move within itself it did & the result is actual clutch slip caused by the dmf.
Don't wreck em they are expensive :Cool:
old-mo
Extra Special
16,346
93,838
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Any thoughts?
Is that using the fully auto mode or going through the gears manually.. ?
When I first got mine.... Not being used to reversing it up a steep awkward drive and taking two bites at it... it would stink of burning clutch.. and flash up on the screen "Clutch Overheat"... :Sad:
But as long as I go up in one motion It`s OK... which I do now with ease..:thumb:
Just done a 4 thousand mile trip abroad with a 4 wheel trailer and car on.... no problems, all done in the auto mode..
Had it serviced a couple of weeks ago and pointed out the clutch slip scenario.. and from a fully fledged "Fiat" recognised dealer he said =
Those vehicles and engine are built for a van or pick-up up to a weight off 2 - 3 tons... NOT for trying to drag 4 -5 - 6 ton of M/home around.. :RollEyes::Doh::Blush:
Why do they build them as M/homes and sell them if they are not fit for the purpose..... I dont know says he.... :Angry::Blush::Blush:
Sep 23, 2013
2,590
8,903
Lincs
Globecar Campscout
I'm sure we were all taught not to let engines labour in a high gear, but to change down (or not change up too soon if going up through the gears).
Then fuel economy got more important, so we were all told to get into as high a gear as possible, as soon as possible.
Diesels are relatively good at giving relatively high torque at low revs & soon run out of puff at high revs, so changing up early was no hardship. I stress the 'relatively' bit because the differences between modern petrol & diesel engines is a lot less than it was 20 years ago in that respect.
Then along came Dual Mass Flywheels, in an attempt to reduce the vibration inherent in diesel engines. Apparently, DMFs really do not like high torque at low revs - in any gear. So we are back to the original advice - never let a DMF equipped diesel have full throttle at low revs & always reach a reasonable speed in each gear before changing up. I notice that my Comfortmatic has a higher change up point than I would use manually when in pootleing about driving mode.
I long since lost track of modern diesel fuelling systems & the detail of how they work, but very few throttle pedals are directly connected to the fuel flow these days - there will be an engine management system in between.
I'm told that city taxi drivers are death the DMFs. They sit in traffic jams & when it trickles forwards, they just lift their foot off the clutch & let the engine recover to tickover speed without touching the throttle. Of course, as the engine speed starts to drop, the engine management system tries to keep the revs where they are supposed to be & boots in a slug of fuel, even though the throttle pedal hasn't been touched. Cue knackered DMF. It's better to raise the revs a bit first, then feed in the clutch. The clutch is designed for it, the DMF isn't (even if it should have been).
Even if it wears the clutch, it's a cheaper item to replace, although given the labour to change either, there is a strong argument for changing both if one needs doing.
That's the story as told to me. Others with recent training on modern diesel power trains may have a different take on it, or may be able to explain the reasoning more clearly.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The comfortmatic is great in most respects but it is not clever enough to read your mind.
With a manual you would change down to 5th or 4th before booting it but in auto the computer only knows that you just put your foot down and goes WTF :Eeek: The power delivery in 6th is far more than the clutch can handle before the computer shifts gear for you.
That's my take on it
39k miles still rolling
EDIT even mild acceleration in 6th can slip as its just too much for more than cruising. If you ever use the cruise control (I dont) you'll notice that even mild inclines result in the computer throwing it into 5th or 4th
RandallC
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
Thanks for the replies.:Smile:
The gearbox is normally operated in full auto
I guess the point is that I don't consider the drive train was under significant load when the slip symptoms occurred. No harsh acceleration or steep inclines etc.
Could be best described as if you had rested a heavy foot on the clutch. Can't quite put my finger on the conditions before it occurs as it's very infrequent and always a surprise. :Eeek:
Portland
923
1,424
Conwy
C class
20 years
I had the early version in a 2003 Hymer with a Sallyspeed gearbox with normal clutch. This had two ranges with a red button to change from economy / normal or winter/ summer settings. The winter setting reduced the gear changes and was good for motorway running but it allowed the clutch to slip at low speed or on hills and could make the clutch overheat ( as we discovered taking the rural route from Santander to Burgos). If yours has this device I would try the difference.
RS_rob
1,010
669
Turnford
My last van was a vw T4 modified I had doubled the power from 88bhp to 150bhp & pushed the torque up to 284.4nm
When rolling road tested it was done in 4th & I asked why it is to do the the power delivery & how the gears are matched to the engine 4th is always a 1-1 ratio.
Needless to say the DMF only lasted a week :ROFLMAO:
43,397
49,955
[HI]Why do they build them as M/homes and sell them if they are not fit for the purpose..... I dont know says he..[/HI].. :Angry::Blush::Blush:
i know why Mo.....because the auto function appeals to motorhome drivers and if thats what they want the converters will use them.
Mar 29, 2011
961
639
Rugby UK
C Class RS
They are just uprated vans and not matter how they uprate them they are still base vans with van running gear and should be driven and used with a degree of care, if you want a proper chassis built to carry the weights on some of these large ones it can only be a Merc or Iveco
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Wont help the OP but will show how they work and what they do
The extra dampening is reqd because modern engines develop so much more tourque at lower revs that it is claimed that standard clutches would not be up to the job.
I does however beg the question ? "Why do they make conversion kits" ie back to a standard set up and how do they manage to work:Doh:
I personally think it is an experiment that all the designers took to cos it gave them something different to draw:RollEyes:
[ame="https://www.youtube.com/watch?v=YnaXB8q3uzQ"]3D animation of dual mass flywheel - YouTube[/ame]
makems
3,440
27,751
Ingleby Barwick,,Teesside
Sadly had to give up
Hmmmm.... our comfortmatic Cruise control NEVER changes down itself.
Ours just gets slower and slower until the cruise control gives up and you return to having to use the right foot. After a while you just get used to having to use the accelerator pedal on hills and take your foot off again at the top when normal service resumes.
Our previous Rapido was on a Merc with a "proper" auto box which did indeed change down on hills when required without any intervention.
I thought the behaviour on our Comfortmatic was just the way it's supposed to be, not being a proper auto.
Now you've got me wondering if there's a problem:Eeek:
Sep 23, 2013
2,590
8,903
Lincs
Globecar Campscout
That sounds like a problem to me, but I can't think what would cause it.
I normally only use the cruise control on motorways & the like, so a gear change wouldn't normally be called for, but I'm almost certain that mine changes gear just as it would if I was controlling the throttle myself.
When you do intervene & press the throttle yourself, does it change down then? If not, it sounds as if the box has switched to manual.
My understanding is that the cruise control operates on the throttle. The gearbox is supposed to react to speed & throttle setting, so it shouldn't make any difference whether the throttle is being set by you or by the cruise control.
Jan 22, 2013
1,258
60,941
London SE
A class Adria vision I707
since 1971
That's not how it should work I'm afraid, once on a incline with extra load the ECU will increase the throttle steadily until the vehicle speed remains steady at your preset limits or slightly below, if it cannot within the turbo boost/ min revs
Parameters it should drop to a lower gear,
I use a mark one eyeball to look ahead :thumb: any hill that would cause a downshift on the box is taken care of by me, a quick flick into a lower gear is so much kinder to engine/ gearbox and clutch,
makems
3,440
27,751
Definitely a problem then.
I'll get it looked at as it's still under warranty.
And no it doesn't seems as if there is any kick down either whci a normal auto box has.
I can't tell properly as I don't drive the damn thing because of defective eyesight. Gwen is the pilot, I am just the observer. :Sad:
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes a problem for sure
I deliberately don't use it because it over reacts like a tw@t :roflmto:
I can get over most hills in 6th without dropping under 50mph. If I set cruise to 60 it would be in fourth before it dropped to 57 :Angry:
Sep 23, 2013
2,590
8,903
Lincs
Globecar Campscout
Maybe they set it like that to protect the DMF from too much torque at low revs. :roflmto::roflmto:
Isn't this where we came in? :winky:
RandallC
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
Well one thing is clear from the comments and replies, whilst the same (titled) box is fitted they seem to perform in different manners.
I was very impressed with the box as it mimics very well what I'd expect to do with a manual. Particularly so the change down when breaking.
There is no evidence of slip when accelerating or on hills. As said occurs around 2,000 rpm under lightish loads. In practice because it's noticeable (I find the slip on torque converters annoying) the revs only rise at most by couple of hundred.
Plan to make carefully note of symptoms.
As a thought any known issues with oil or filters etc.
incidentally the box has only done 12,000 miles. Previous owner didn't go very far it seems.
Aug 9, 2023
Fiat Ducato
Any thoughts?
Hi I use the forum and Im having the same issue with my Fiat Ducato did you manage to sort this out and get to the bottom of it?
RandallC
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
well, yes and maybe could have been cheaper.
At that time was not aware of the comfortmatic sublties and went for a clutch replacement as looked at the issue from a conventional manual box point of view and dual mass flywheel probs. (After all its a robotised manual box and clutch) So it cost a few bob, cant remember exactly, but much later having read the experiences of others with CM boxes, first stop is reputauble fiat garage with the software to do a clutch relearn AND while there get the fluid changed.
If that doesnt sort it hold tight to your wallet and look for someone to replace the clutch and probaly dual mass flywheel.
Feb 19, 2020
1,442
1,587
North Ayrshire
Adria Matrix 670SC
Newbie
I have a comfortmatic, it definitely changes down when hitting a hill on cruise control in fact if you are set at 60mph it changes back and forth between 5th and 6th far too often. I've learned to set it at about 62mph to stop it doing it.
Feb 19, 2020
1,442
1,587
North Ayrshire
Adria Matrix 670SC
Newbie
I have a comfortmatic, it definitely changes down when hitting a hill on cruise control in fact if you are set at 60mph it changes back and forth between 5th and 6th far too often. I've learned to set it at about 62mph to stop it happening
RandallC
RandallC
1,242
3,488
Devizes
A Class Rapido 8096
Ditto any auto box dependant on hill, etc ,etc.
Once had a SaaB 95 estate that wound me up due to its NEED to down shift and rev it's self excessively for no apparnet reason. (had another set of words to do with nuts but though better of it)
