I don't think there's anything to worry about . Sound removed to protect innocent ears.
I've got VB full air on my Geist and it rides lower than before. It was very high at the back on the standard Fiat suspension. They lowered the back rather than raising the front, so the tanks sit very close to the ground. I've only brushed them on aggressive speed humps couple of times though. And I've got the option of lifting the suspension, which I've used to great effect on some very rough ground.we're thinking of getting air suspension fitted
Kon-Tiki 894 2024 model
On a separate issue - what is white material (polystyrene?) on top of the outrigger?Kon-Tiki 894 2024 model
I assume it's for vibration damping and possibly thermal isolation? Composite foam board is pretty darn stiff.On a separate issue - what is white material (polystyrene?) on top of the outrigger?
I have never seen that before.
Normally the underside of the floor sits tight on top of the chassis.
Are you surprised ? Thought notAre you say Swifts flagship model has an underslung water tank.?
That looks very vunerable, everything to do with that water discharge should be just above the bottom of the chassis rail, did you add the white cable tie?
I have the same issue 2023 modelWe have a swift kontiki 2023 plate and at least 12 times I go over a speed bump or slight incline and both hangers get torn off and I lose all water. Waiting for swift to reply but to me it seems a very bad design and my engineer friend in Spain also states the same and compile a report. Has anyone had similar problems ?
Driving us mad
Steve
That looks like a decent bit of kit, good luck with that.Happy days just got rid of my Swift pile of junk the worst vehicle I have ever had the misfortune to own now bought a Rapido M96 love it
