You could swap side to side if you remove the tyre from the wheels. But if just moving the wheels around, then they would end up going backwards, if directional treads? Which would not be good for braking.I was told, many years ago, that swapping tyres over was OK, as long as it was only front to rear, and rear to front.
I think I spotted a post earlier in this thread in which somebody mentioned that he swapped his side to side ?
Maybe I imagined it ?
Nevertheless, with the introduction of radial ply tyres, and the phasing out of cross plies, in the late 60s, early 70s, swapping side to side was no longer recommended.
Sommat to do with the construction of the tyre relative to a 'set' that any radial takes on when run on a particular side of a vehicle for any length of time.
It's all related to 'angles'. Caster, camber, toe, steering axis inclination, and toe-out on turns.
These angles, cause a radial tyre to take on what can be referred to as a 'set', which, when the tyre is fitted on the opposing side of the axle, will cause a more noisy and uncomfortable ride. It could also lead to more rapid tyre wear.
It's only what I was told years ago, but I suppose it might be right.
Supposedly the construction of the cross ply tyres of old would not be affected, in the same way, if they were removed from one side of an axle and fitted on the the opposing side ?
I could be completely wrong here, but it makes for interesting discusion ?
