Super drug unlimited data sim
I have a TP myfi with superdrug Sim. Just driven through France now in Spain and although it worked when set up in the UK I can’t fathom the APN settings any help appreciated.
If you manually search for networks does it find any?
Thanks for that, no worky still. Will look at the Superdrug site again.
Here are the APN settings from the Superdrug site - see attached.
Used it in my Netgear Aircard 790S all through France, Spain and Portugal last Winter, Dec, Jan and Feb,Worked Faultlessly, cancelled contract on our return...as only use Moho in the Eu in the Winter...use phone data for the UK.
Switched back on Dec 1st this Year, ready for our Dec 2nd sailing to Spain, Used it passing through Spain and now in Portugal, No Issues at all, up to 15 Devices if required, No VPN Required...
Same settings as above post...
You were lucky it still worked, like most Sims after 6 months of not being used they are often deactivated.
Had a 3 Sim that was inactive for over 3 yrs,reactivated it and worked fine...kept it just for the Number... ***99911199
Just log on to your superdrug mobile A/C, and you can cancel/reactivate at will, as its a monthly rolling contract...No Luck involved.
From the terms and conditions.
If your plan isn't active for 180 days, we'll close it down for you. If you want to open a new account after this time, you’ll need to register again.
Success thanks. In the end I took the Sim out of the TP link myfi and put it in the OH’s iPhone. It activated straight away, after using it as a hotspot for an hour I then replaced it to the TP myfi and success. Thanks for your help.
But I'd closed my down before it became inactive for 180 days, so they didn't have to close it for me...
I was answering the Op's Question, not having a debate about the in and outs of a ducks a*s...
Fitted mine in my huawei router in Spain after checking it in uk, does not work, spoke to Superdrug and they said you cannot tether with it so I cancelled my direct debit.
If you didn't use it until you got to Spain it won't work. You have to initiate it in the UK. Also best to use it in the UK before traveling, I used a few gig on mine a couple of days before we left the UK.
My Superdrug SIM was activated in the UK but not used before being posted to me in Portugal.
This was last year, worked fine for a while and then they pulled the plug citing suspected fraud, never found out why and I have not bothered since.
I’ve activated my sim
put it in an old iPhone 8
changed the APN settings and it works fine
Do I need to reset the settings if I move it to maxview roam unit ?
The Roam should work straight away using the AutoAPN function. If it doesn't, you can enter the APN settings manually using the Roam App or the Router's WebUI.
If you get stuck, just give us a call on 01553 811000.
Not being used was probably the problem, I used 6GB on mine in the UK and had no problems with it.
Same here. Activated in UK and given a weeks hard use before heading abroad. No problems in 3 months away.
Update on another thread ... now limited to 12gb when roaming:
