Sub 3500 kg A class
Is there a realist A Class under 3500 kg with a realistic workable payload, with a fixed low level bed. One that does not need a ladder to access
few weight saving tips i would like to share .wear string vests and string pants. fill the food draw with rivita fill the fridge with chocolate moose.(not a real moose covered in chocolate thats weired )and if u want to get a bit flash and splash the cash and posh it up a bit get some ferrero rocher them things weigh sod all
We run our Carthago Compactline 138 at 3500Kg( 20Kg under). Two folding e-bikes, full provisions, clothes, fuel and water and fairly light occupants. Two steps up to the transverse bed.
Yes agree, 2945 empty is very optimistic
It’s also not double floored if that is what you are wanting an a-class for. We’ve got the C86 on order which we think is ideal for us. The i version is virtually the same apart from the wider cab.
We’re having our factory unrated to 3650 in anticipation that it’ll be tight weight wise
In my experience, 3650 is still way too light, mine is uprated to 4000 and then we are ok. Thats the most the alko chassis will allow.
The 3650 is a paper thing. What did you have to do to go 4000kg?
Needed rear air on the alko struts - fitted by SAP. May also need front shocks upgrade, but already fitted if 9sp auto by Fiat….apparently they have to for the weighter gear box over a manual?
Wheels already heavy duty alloys.
Cut the handles off your tooth brushes and fill the garage with helium balloons.
Van Weight Engineering got ours up to 3960kgs as a paper exercise.
Front axle is 1960kgs on the auto version.
That’s good to know. Are you on the 140 or 180 engine? I’ve ordered the former and hope it will enough…though probably overthinking
The whole idea is if we don’t get my C1 entitlement this time may have to downsize (76) currently running a 2019 Burstner IEXO A class with good spec uprated to 4500kgs.
Yes, it can be done.
We run our Hymer Exsis-i 580 at 3500Kg. One mobility scooter (with LiFePO4 batteries), full provisions, clothes, fuel and water and two occupants. No ladder needed for longitudinal rear beds over garage. If you can get in the van, you can get in the beds
140 , and I don't find it short on power.
Patrick
I've got the 180 with the Auto box has 450nm of torque I wouldn't want anything less.
Don't see point in having the 180. Have done 10,000 miles since new and power has never been an issue.
Usual travel at around 60 mph, mostly in 9th gear, can't see a reason to pay more for something that's not needed.
Also averaging 30 mpg ,which I'm happy with. (y)
I've got a 6m a-class. The van we ended up getting has the bed over the cab (which does need a ladder). Because the bed doesn't drop over the lounge, we can use the lounge while the bed is down. And we've still got high level lockers around the lounge, which we'd probably lose if there was a drop-down bed. So it being an a-class added loads of extra utility and storage to a relatively short van.
I did consider a 6m Globus with a fixed rear bed. But I wasn't convinced that it being an a-class added that much. The semi dinette wasn't much more spacious and the storage didn't really change.
I didn't pay more it was standard but if I had to I would have. My last van was a 150hp, the 180 is so much nicer to drive.
