Road Runner
How many times have you heard of anyone being robbed in their van
Me, we've been robbed while in the van. Most know how I think it happened but will leave it at that.
If there is nothing strong enough to thread a cable through than you cannot use this method, however the duoSafe should fit and it will do the same job. It slots down close to the window glass and prevents doors opening and at the same time provides a good visual deterrent. It is very light aluminium and when not in use it packs down small and is easily stored.
<John Cross> probably sell them and they give Funsters a good discount:thumb:
Does the duosafe lock in place - if not what's to stop a thief from removing a quarterlight and reaching in to remove the duosafe?
On my van it doesn't have anywhere to fasten anything to the door, also the duo safe only lists the Renault Master before 06/2006 :Sad: there are a couple of holes in the plastic moulding low down on the door but I don't think they would stop anybody.
he tends to deter unwanted types:thumb:
While on the subject of security I was looking for some alarm signs to fit on my lockers to warn of the alarm I have fitted and came across this image006.jpg (image)wonder what made the holes
Re "Gas Attacks"
This has been a seriously long subject of debate on other Forums! Here is a copy of a letter apparently from The Royal College of Anaesthetists to a member of another such forum.
Thank you for your enquiry. I would like to inform you that you are not the first enquirer with this question. Professor Hatch, our Clinical Advisor, has given the following previous comments:
"I can give you a categorical assurance that it would not be possible to render someone unconscious with ether without their knowledge, even if they were sleeping at the time. Ether is an extremely pungent agent and a relatively weak anaesthetic by modern standards and has a very irritant affect of the air passages, causing coughing and sometimes vomiting. It takes some time to reach unconsciousness, even if given by direct application to the face on a rag, and the concentration needed by some sort of spray into a room would be enormous. The smell hangs around for days and would be obvious to anyone the next day.
There are much more powerful agents around now, some of which are almost odourless. However, these would be unlikely to be able to achieve the effect you describe, and the cost would be huge enough to deter any thief unless he was after the crown jewels. The only practicable agent is probably the one used by the Russians in the Moscow siege - I advised the BBC on their programme about this. The general feeling is that they used an agent which is not available outside the KGB!
Finally, unsupervised anaesthesia, which is what we are really talking about is very dangerous. In the Moscow siege about 20% of victims died from asphyxia, because their airways were unprotected. If the reports you talk about are true I would have expected a significant number of deaths or cases of serious brain damage to have been reported."
I hope this information is helpful to you.
Regards Pat
Mate of mine was gassed in his cab outside Northampton and his trailer was emptied of several hundred industrial micro-waves. - 3)Colleague was gassed while reading in bunk in his cab, on the road between Barcelona & the border, robbed & relieved of his load of shellfish. 4)&c &c &c, 9 occasions that I know of personally in a 3 year period - many more heard of from acquaintances.
On 2 occasions the tank of hospital anaesthetic gas was found under or beside the truck.
I would like to be able to strap my doors together when we leave the van. However my Renault Master doesn't have anywhere suitable to thread the cable. The door covers are plastic so I can't see anywhere to secure a fastening. Does anyone know if there is somewhere on the door that is suitable for screwing into?
Thanks.
