Ah - OK, well our previous van was brand new, so the battery in theory was too - must have been stored badly at the dealer or something.It's Type 19 at 90Ah and only 2 x years old at most Adrian. Every time I'm in the side locker where all the CBE electrics are, the BM is always showing green, (charged), rather than red, (charging). I had the CBE CSB2 on the Hymer, ( a great little charging unit), but this one on the Flair is the Vanbitz BM.
Cheers,
Jock.![]()
Our (Carthago) CBE DS470 fuse box system paralleled the cab and hab batteries when the main panel was on and voltage was above 13.5v. It gave up to 6 amps - I think earlier systems used a separate little box, but ours was integrated), but not when in storage and the panel switched off, so we popped the CSB2 on to cover that time in storage which worked well and the van always started - but I should've checked the battery - it was knackered, and the Merc base vehicle with its telematics etc plus our tracker did seem to use a lot.
If yours is similar, and the batteries are paralleled would that cause the green led to show?
Our current van when in storage, but with the Victron Cerbo, Solar Controllers, Ablemail (like a BM) and mifi turned on uses a steady 0.8amp If I leave set the Ablemail to run permanently, rather than on it's normal programme which reduces the draw to less than 0.5amp, so I guess thats up to 19AH per 24hr, normally compensated for by the solar output.
