JockandRita
- Aug 2, 2007
- 12,164
- 163,370
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Our Sterling 60A B2B has served us well over the last 3-4 years, (as did our 50A unit in the Hymer), charging our Gels first and later our SLA batteries.
With our new LiFePo4 batteries, it is still performing well, and on the correct charging regime for them. With the built in CBE distribution system, the AES F/F takes it's 12v power @16A from the leisure batteries, so with a recently tested 45A output from the Sterling unit, only about 30A of that is going into the batteries.
To those in the know.............would the Victron Orion 50A B2B perform any better, or quicker even? I am aware that it is cooler in operation, and that the Sterling unit does throw out some heat from the installed fan. It is connected via the ignition feed.
Whilst I appreciate I can link the Victron unit to the other Victron items via the VRM App, and have them all communicating with each other, I am loathe to spend £300 on a charging facility which I already have and appears to be doing the job well, albeit lower tech.
Apart from a lack of Blue Tooth connectivity to the Sterling unit, are there any other disadvantages of it, compared to the Victron unit?
Thanks in advance,
Jock.
Thanks in advance,
Jock.
