AlunandFelicie
- Aug 20, 2018
- 933
- 11,877
- Burstner lyseo time
Always worth checking earths with any electrical faults.but might be worth checking the earth
Isn’t that a motorbike?I fitted a Yuasa 5000 a couple of years ago.
Another battery?????Just checked it the original Fiat labelled battery so coming up to six years old plus time on shelf !
best type to replace with?
Somebody‘s won the knee in the nuts prizeAnother battery?????
How kind!Somebody‘s won the knee in the nuts prize![]()
12.3v on as sealed lead acid battery is approx ~~ 50% charged...Our van failed to start yesterday after a long lay up on EHU ,the panel shows 12.3v and we have a battery master fitted ,it tried to start all the lights on dash as normal but didn’t kick over , as far as I know the battery is the original (18 plate) so time to renew?
But you will pay top dollar for the battery and they will fit the battery they make the most profit on.I fitted a yuasa last year. Go for the best you can afford. If your in the rac call their battery service. They will test your old battery and fit a new one to the right spec on your drive or wherever if your not sure.
So, no Knee in the Nuts for me then due to my previous advice??New battery fitted ,started on first turn of the keyhappy bunny
Oh ok then if you ask nicely You can still have your treatSo, no Knee in the Nuts for me then due to my previous advice??![]()
I don’t think so (buggered if I knowDid you need to code the battery with the van?
Our Merc van needed that done, something to do with the charging and stop start......Did you need to code the battery with the van?
Me no gottyIf you have start/stop on your vehicle the battery will likely need to be re-coded with the new battery in place otherwise the stop/start may not work as expected.
Which battery did you go for?New battery fitted ,started on first turn of the keyhappy bunny
Same one we fitted to our Ducato earlier this year after the previous 4yr old Varta gave up the ghost.I fitted a Yuasa 5000 a couple of years ago.
i changed my batt 4 months ago and i have a stop start , did not re code? all working Fiat ducato must be diffIf you have start/stop on your vehicle the battery will likely need to be re-coded with the new battery in place otherwise the stop/start may not work as expected.
I have just replaced ours (original Fiat )on our 2018 Hymer with a Yuasa 5000 it has a five year guarantee and high crank amps.Just checked it the original Fiat labelled battery so coming up to six years old plus time on shelf !
019 is what I fitted to my 2017 Ducato.Just had quick butchers to see possible cost. first need to know what size to fit options seem to be 17,19,20,100?
As with all number plate systems my model is not Recognized "Fiat Rapido" a 2.3 2017 Ducato. (still on original)
Actually I'm wrong - I was going to buy that one, but whilst 'considering' options, the price rose by about ~£40, so I ended up buying an Exide Premium locally, for about the same price as the Yuasa would have been from one of the big online battery suppliers.Same one we fitted to our Ducato earlier this year after the previous 4yr old Varta gave up the ghost.
Yes, same size was needed in our 2013 (X250) Ducato.019 is what I fitted to my 2017 Ducato.
I paid £105 from Halfords (with trade card) for the Yuasa cheaper than anywhere else but it was over a year ago.I was going to buy that one, but whilst 'considering' options, the price rose by about ~£40, so I ended up buying an Exide Premium locally
