Squeaky Squeaky Squeak - ARRGHHH!!!
Hi Paul
Did you ever find the cause? We have what I guess is the same annoying oven area squeak in our 794i…..
Today I found it... I'm going back to the bus with a set of tools and I'll do a write-up. Right hand side of the oven is a trim panel secured with screws. Gave these a tweak whilst 'er indoors was barreling down the M4 and it stopped.. Banging!
Coupled with the mod I did to the skylight, I have a silent bus :) Only taken 3 years.
Well done!
My squeak came from two of the horizontal bars on the Truma gas fire. One had somehow got bent and was rubbing against the other one.
Probably quicker than letting Bailey solve it well done ! I dong miss thd squeaks lol
As promised...
On the right hand side of the oven is a trim panel which is held against the drawer cabin by a 'sticky pad'. This, over time has lots its adhesive properties and allows the piece of trim to move. The screws holding the trim panel were loose, the lower one was 3/4 of the way out. By moving the trim I could replicate the squeak.
Tightened up the screws holding the trim pieces and inserted a thin shim between the trim and the cabinet and its done. No more squeaking.
Happy Days.
