Squeaking at rear...suspension bushes ? (1 Viewer)
Jan 31, 2016
2,063
3,724
Alness, Cromarty Firth
Hymer B534 DL (2017)
Well travelled
We have loud squeaking coming from rear of our Hymer. We have semi air suspension on rear as well
But suspect it's the bushes on the leaf springs
Anyone know better or had this done ?
Chassis is heavy Fiat so doublspring type.
Oct 8, 2014
1,720
3,314
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
I've got the same problem. A garage replaced the spring hangers and bushes with latest Fiat parts, but still not solved the creak. They now think it's the bushes in the actual springs. Unfortunately Fiat only supply the bushes as part of new springs. I have opted to have the bushes replaced with pattern parts for now. I will report back Friday evening, after the work has been done.
Dec 24, 2014
9,878
51,900
Hurstpierpoint. Mid Sussex.
Compass Navigator
When I was in the trade it was known as 'scrooping' - usually worse in hot dry weather. We used to squirt brake fluid onto the bushes which worked its way in over a few miles driving, stopping the noise.
Nov 27, 2011
17,851
44,358
A bit of dust between the springs or even light rusting makes an awful racket. Yes the bushes squeak, but the leaves are often the cause
Nov 4, 2011
6,342
43,689
Uk
We have double springs on our Hymer, I Jack it up periodically and part the springs with a screwdriver and grease them with assembly grease.
Apr 6, 2019
4,331
8,558
Eye, Peterborough, UK
RV
FourWinds Windsport 6.8L V10
Some leaf spring bushes when fitted are supplied with a tube of specific grease. Presume it must wash away eventually.
Sep 25, 2009
812
1,452
south yorkshire
since 2004. Tugger 10 years on and off
Another thing to check.I had the same.It turned out to be the handbrake. Next time when driving lift the handbrake up a tiny bit .But don't pull too hard.It disappeared on mine.My local garage sorted it for me.
