Ivory55
You mean that you managed to get past the tractor, hahaY.ep and the speed limit goes up and down like a yoyo and not always to the next allowable speed on the Boston Skeggy road
Hi.The sat nav in my new Fiat drive's me mad constantly telling me "You are exceeding the speed limit"
That's it - it does!!! How did you know??Hi.
Does yours..... " Echo ? " It seems to be coming from the passenger side.............![]()
Yes dear......... I heard it....... Tell these other..B.....B............BLIGHTERS passing us...........................
Tea Bag
If your motorhome has Ducato/boxer/Relay gauges it is possible to add a speed "beep" to remind you of the speed you are travelling at without looking at the speedo. I set mine at 65mph but that doesn't help with lower speed limits I know.Having been caught speeding twice within the last 4 decades, I have now been caught twice within the last year.
(Both times by cameras and about 7mph over the limit)
Does anyone have a recommended device that will give an audible warning of a speed camera approaching ?
Years ago I had a AlerteGPS device, I've just found it and plugged it in for the first time in a decade, it still works but the data will be from before 2010.
It also has to be switched on each time you drive and takes several minutes to find the satellites, so only really good for long journeys.
There seems to be an app called RadarBot - Anyone used it ?
I'm really after something that will fire up on it's own and just give a warning if there is a camera about.
Mine is set at 30 mph.If your motorhome has Ducato/boxer/Relay gauges it is possible to add a speed "beep" to remind you of the speed you are travelling at without looking at the speedo. I set mine at 65mph but that doesn't help with lower speed limits I know.
As far as I'm concerned, the problem is knowing/remembering what the limit is more than the speed you're actually travelling at.Best device is- look at the speedometer
this device is designed to tell you your speed
And - of course, obey the law
Observe the speed limit
( yes: just like the rest of us)
But that won't warn against mobile cameras.Sounds like Road Angel comes out on top, at £200 or so, it's probably worth it!
I don't think it's good to be studying the speedo, so I've used a speed limiter for the past 15 years.
I also have Road Angel. The Road Angel tells me my speed, which is very useful in the motorhome where my dash spends most of its time in 'stealth mode' (invisible) but it does require a subscription (which was rather irksome during lockdown). The Road Angel also tells you what the local speed limit is, so you can set your limiter correctly. Be wary of the Fiat limiter, however, because it does not work properly and will let you exceed the limit.
If the authorities were genuinely keen to help us keep within their limits, you'd think they'd try to make it easier for us because all of this could be automated so easily. It's surprising how often the limit can change along 'normal' roads and keeping-up with them can become rather tedious.
It's also noticeable how the road in front is usually clear, whilst a queue can build up behind. It seems that many are overly keen to complete their journey without regard to limits. Try not to be drawn into that rush by the flow of faster traffic if you want to avoid the speed controls (always referred to as a safety measure but keenly exploited as a means of revenue).
I don't see that as the problem.But that won't warn against mobile cameras.
There is a road on the outskirts of Newcastle that is a 30 limit and there is a mobile camera there on a regular basis so you can never be too careful. Although most of us try to obey the speed limits as you say it is easy to get caught out by straying a bit over the limit.I don't see that as the problem.
On the open road I typically set the speed limiter to the max permitted.
The places where I have been caught are very urban places with a 30mph limit where I was doing 37mph.
There is one road I use on a regular basis that has 14 speed cameras in each direction (28 in total) over a 5 mile length!
Whilst I'm unlikely to be caught there as I know it, it's the ones in less familiar areas that cause issues.
Wrong:But that won't warn against mobile cameras.
Waze - free navigation app for smartphone, although designed for cars so if you use it in your motorhome you might get show some unfeasibly narrow roads.
In practice I often use the speed limiter function, rather than cruise control, so I can keep eye on the road, rather than concentrating on the speedo, especially in the average speed camera areas that have become the latest wheeze.
I thought speedos or jammers were mandatory in Franceyes, unfortunately, so are jammers![]()
It warns against the database of mobile cameras and reported sites by other users. If you are "painted" by a mobile camera and you are exceeding the speed limit then you are done. It will not warn you of an actual live camera until the laser hits you, unless you get the warning for a designated siteBut that won't warn against mobile cameras.
I think that it has saved me a few tickets by reminding me of a) cameras and b) exceeding the speed limitWrong:
Road Angel does warn of mobile cameras, although it's probably over-cautious and may not warn of first-time (fresh) appearances.
The annual premium covers the cost of mobile communications between you and a control centre. Users can alert them, and hence others, of the presence of a mobile unit. I think it becomes 'official' when more than one report has been received.
I don't pay much attention to the speed trap warnings, although I sometimes look to see where an alerted mobile unit could have been (there a lot of 'false positives').
Road Angel tells you what kind of camera to expect (as if that should make any difference) and also detects radar.
It appears to do whatever it possibly can to help you avoid exceeding the limit and may be the best at it but, like all good things, does not come cheap and requires a continuous subscription. I do not know if it's the best or even the most expensive but it has been both of those for me, of the few that I have owned.
Really ?Increasingly not, they are being set for environmental reasons to reduce emissions in polluted areas.![]()
It's not easy to calculate what the cost of a speeding ticket would be, but the subscription may more than pay for itself if you are otherwise inclined to ignore restrictions.I think that it has saved me a few tickets by reminding me of a) cameras and b) exceeding the speed limit
Quite agree. It is a great digital speedo. Speeding ticket £100 is OK but the increased insurance on each policy for 4-5 years is definitely not.It's not easy to calculate what the cost of a speeding ticket would be, but the subscription may more than pay for itself if you are otherwise inclined to ignore restrictions.
For me, the prime purpose of my Road Angel was to overcome the appalling dash that Fiat saw fit to provide in my cab.
[It used to be a legal requirement for all road vehicles to have a working speedometer and I assume that's still the case(?) I'd assume that it should also be readable at all times? I just don't understand how they get away with it!]
Perhaps you can explain that to those who have promoted speed limits for air quality reasons.Really ?
Care to remind me what a DPF does, and how / when it works ...
Well done you! It seems that the police are not interested and do not have the resources to police speed limits in villages so we are hoping to set up a Speedwatch team.I have been out this morning on Community Speedwatch. 8-9am when children walking to school. Oh the sound of braking when they saw us. The worst one recorded was 51 mph, it is a 30 mph zone.
SWEMBO does it for me. And she warns about every other possible hazard or problem as well.Does anyone have a recommended device that will give an audible warning of a speed camera approaching ?
