I don't think that letting any air out will make it fit as tyres are still quite rigid and it will then put pressure on the tailgate which isn't a good idea.
I used to sell ‘gunk kits’ over the counter and had all my trailer hire fleet filled with them.I WAS a great believer in gunk kits, that’s all our Hymer was supplied withView attachment 589968
You’re right! It doesn’t alter the rolling radius significantly. The only car I’ve had that accommodated that was a Porsche I bought during my midlife crisis! The wheels were huge and the spare tyre actually folded in on itself, on a full size rim. Very clever and very expensive but, it needed inflating every time it was used!I don't think that letting any air out will make it fit as tyres are still quite rigid and it will then put pressure on the tailgate which isn't a good idea.
I knowHe said it not me.
All that air inside the tyre don't half affect your payload dunnit!I used to carry a flat spare before. Well about 15mm I, so wouldn’t take long to bring up to pressure.
Yes it's a good alternative if you can't/don't want to carry a 'ready to use' one.See suggestion of mine on post #18, at this time when sourcing certain tyres can be VERY time consuming, it has been a quick solution and very little weight.
I've got this image in my head of Mo huffing and puffing trying to close the tailgate with Judy standing beside him telling him what a silly sausage he is!You’re right! It doesn’t alter the rolling radius significantly.
Clever idea but don't suppose it did the tyre much good folding it though?The only car I’ve had that accommodated that was a Porsche I bought during my midlife crisis! The wheels were huge and the spare tyre actually folded in on itself, on a full size rim. Very clever and very expensive but, it needed inflating every time it was used!
Eventually, I grew up and got rid !![]()
Reminds me of a tale many years ago, when I was still employed as a retail shop manager In an outdoor chain!I know
The inside of a tubeless tyre is very different to a tube tyre., When tubeless first came about, I always used to fit a tube inside, does anyone continue this practice?? (I don't)
You wouldn't want to go far at 20mph.....the legal limit for such a rig.You could buy and attach a trailer behind the TOAD for it![]()
The tubeless will rub on the tube eventually rubbing through.
It's advised never to tube a tubeless tyre.
However, I think its questionable, how much the tube would move about inside a tyre when it's trapped by 50psi air pressure and the valve through its hole?![]()
I put a tube in a Wheel Barrow, and the tube moved inside.... twas the wrong size tube...![]()
I have outright refused to buy a couple of cars in the past fitted with run flats.Could fit a Run flat
