Solar panels to controller cable size (1 Viewer)
Jul 4, 2024
dont own one yet
Hello,
I think I am posting in the wrong group but would appreciate if anyone can share their knowledge regarding solar panels and cabling.
I am looking to install 6 solar panels connected in parallel ideally on my outhouse flat roof with the below spec and the distance Between the panels and the controller would be approx 10meters.
1. Maximum power ( P max) = 300Wp
2. Open circuit voltage (Voc) = 40.11V
3. Short circuit current ( Isc) = 9.61A
4. Max power Voltage ( Vmp) = 32.54V
5. Max system Voltage ( Imp) = 9.22A
Online calculators suggest 35mm cable, is this correct or would a 6mm cable would be enough ?
Please suggest if connecting 3 panels in series and 3 in parallel would be a good idea to reduce cable sizing
Thanks in advance
Regards
Harsh
Oct 8, 2014
1,684
3,172
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
What is the maximum input voltage and make/model of the solar controller that you plan to use?
Are you planning to charge 12v or 48v batteries?
Dec 2, 2019
4,289
9,623
South Lincolnshire
Rapido 7065+
Broken most bits now
If you're looking at a 240v domestic system then the voltage/wattage capacity of the inverter will limit the total volts of the panels in series. If you need to put them in parallel in a 12v setup then there will be a limited number of controllers that can deal with the amps
MisterB
6,399
14,605
Adria 670 SLT
If it's a domestic install, most solar panel installations use 6mm (or 4mm) cables between the panels up to the inverter in my understanding.
Jan 2, 2024
678
894
Lincolnshire, UK
Peugeot boxer
Not the norm to parallel all panels for six panels .Panels are wired in usually series strings then strings are paralleld, if controller only has one input..,number of panels in a string and number of strings governed by controller input capacity
Sep 29, 2007
831
1,287
Wantage, UK
Motorhoming since 2006, 30 years tent camping in Africa
Why all in parallel?
I’d suggest series, or at least one or two in parallel and then place those is series.
You might get away with 10mm2 cables if you want to stick to parallel. It would mean accepting a 10% loss and cables heating up to 70degC. I’d not install that personally, I’d place them in series.
Oct 8, 2014
1,684
3,172
Wiltshire
See my post #2 - The OP still hasn't said what solar controller he plans to use. I want to wire domestic solar panels to a Sunsynk Charger/Inverter and the input voltage is 120v MINIMUM.
