Just having read the rest of this thread i didn't realize this was all your idea.I wonder if you could use 1 or 2 car hatchback struts to pop the panel up. All you'd have to do then is take a bolt out and it pops up. Most would maybe be too powerfull so you'd need one for a small door or the ones that just open the rear glass would be weaker. Might look into it myself thinking about it![]()
(struts came from the spare Bongo inner roof i had)
thanks, i only thought id borrowed the hinges. the other thread shows the experimentation of strut location versus angle. works a treat. i mounted the struts upside down and inside the panel to aid weather proofing.
Thanks again best idea i never had
Tilting solar panels
Has anyone done a roof tilting panels with actuator or without? I’m in process of finishing mine. Initially I had two fixed and I had to start from scratch, without access below roof. I’m interested in what others have used for hinges. I tried few combinations, and settled for the fire rated 4”...
