Phil89a
Do you know why it is "frowned upon"? Would have thought it is no different than popping down the shops in the van.You'll definitely need a second battery with a compressor fridge, however I'm surprised at Ash's comment regarding running the engine to top them up as this is usually frowned upon.
I think once you 'taste' being off grid you'll want to do it more and/or for longer periods so solar will become a necessity but not at present and can easily be added later.
As for the second battery, your dealer may be able to do this for you but if so make sure they are matching it with the existing one (don't just specify that they match each other). We had two dealers who removed the original and replaced it with others despite us stating we just wanted to add another matching the original, the first time we spotted it when we went to collect and they had to remove them and put in ones of the same quality as the original, the second dealer put in 2 new quality ones but unfortunately the charger wasn't set-up to work with them so they had to pay for 2 new ones and for them to be fitted locally.
Nearly forgot, engine size, 140 will be more than sufficient I'm sure.
Ash did recommend getting the second battery as factory fit to be sure they are matched and to ensure the charging system is correct. So I will go that way to be safe.
I am still thinking of adding a Solar Panel and going "factory fit" (as it just feels right to have one ) and I am sure it helps resale when moving on. So for now the 120w is still on the list (just need to confirm the weight).
Phil
