RS_rob
My partner has it sorted, the day before we go away she pays to have her hair done & if it's longer than 3 days we have to stop for either EHU or the site must have nice toilets with electric sockets.
Martin
What inverter do you have ?
The average van does what the average person wants to do, adequately. However, when you want to do things or use things that many wouldn't dream of using you need to change, adapt or upgrade the equipment installed by the manufacturer.
We "don't" need solar panels, but many people use them, I have three 130w solar panels, each controlled with a Victron MPPT regulator, but then I have over 800 Ah leisure battery bank.
I need such a size as I use the inverter charger that the OP mentioned. I prefer it as I like the "power assist" function. As a inverter charger, it is a 2000 watt pure sine wave inverter, (will peak at 3000 watts)
The power assist function will make up for any shortfall on electric hook up. If my wife decides to turn on her hair dryer, whilst the inverter is running the TV's and the Sky+ box and there is only 6amps on the hook up, the 100amp multi stage charger stops being a 100 amp multi stage charger, and immediately inverts the "shortfall"
As soon as the hair dryer is turned off, the unit flips back to being a 100 amp multi stage charger and replaces the power that it has used from the batteries. This eliminates running around looking for a trip switch to reset the system, normally in the rain and mud lol
I can also use it as a UPS (Uninterrupted Power Supply) This means that if I leave my Sky+ on record whilst I am out and someone comes along with a dodgy set up, plugs into a bollard and trips the bollard, my system will immediately switch to invert mode, and the Sky+ box carries on as normal. If the electricity supply is re-instated the inverter will switch back to stand by and start charging.
It is a great piece of kit, fully programmable from the LCD remote panel, and can even cope with frequency differentials, so on an RV will work with 60 cycles from the generator.
Yes you can buy cheap stuff, yes some can install all these things them selves, yes you don't need hairdryers, heated towel rails and coffee machines! I think that we all understand that. But, my wife doesn't want to use a dry flannel to dry her hair, I dislike damp towels normally fabricate an additional heater outlet or tube heater to ensure their nice and dry. I dislike adverts on TV, and at home I record most things and skip through the adverts, why should I want to do anything different in my motorhome, when I don't have to? and I like coffee the way that "I" like it. Not everyone is comfortable taking their new motorhomes to pieces, or have the ability to make bespoke battery leads 8m long Not everyone wants to buy cheap stuff of eBay and be "on their own" We as a Company wont supply or install things that we haven't tested or had tested ourselves, and I wouldn't dream of putting unbranded Asian imported stuff onto my motorhome. I didn't buy the cheapest van on the market, so I am certainly not going to fill it with equipment, that is the cheapest on the market not the best.
OK
I have 300 watt solar feeding 500ah battery bank via mppt regulator.
This battery bank only feeds the 2000/4000 pure sine UPS
Surplus solar charge is sent to the habitation 2x115ah Elecsols (Vanbitz) via CBE CSB2 relay (me)
The habitation batteries are also supported by a 50 amp BtoB (Vanbitz)
The habitation batteries then have a battery master (Vanbitz) to support the starter battery
My Habitation and Solar battery bank can be interchanged or combined by my battery selector switch (me)
I have so many options the lights will never go out!
I can also run the AES fridge on 12 volts on good summer days with ease.
ive seen power stations with less wiringIt has never got close to being discharged so far but yes the B2B will charge or try to charge all 6 batteries if I combine the two banks with the selector switch.
With the recently installed UPS I could hook up now in an emergency to charge up all the batteries as the habitation still has its original CBE charger while the UPS has its own 15 amp 3 stage charger.
i have 3/ 120 amp batteries powered by [here goes] 100/@70 solar panel,s through a quasie 1000w inverter + panel [am not up on this] to charge ann,s [wife] breathing machine,mobility scooter,plus normal m/h / thing,s kettle toaster
both 7oo/8oo/ all sorted less vat apprx £700
I didn't say that the dealer wasn't reputable! Or mobile, but you really need to have a RCD fitted on the output of the inverter, else you have no protection against electrocution when using the inverter in the even of a faultmy system was installed by a reputable dealer, at my home, i also have an mppt thing and on off switch when on ehu also a battery display,as u probably now as with most things u leave it to the professional and hope they now what u want and supply same,to date all seem,s 2 b ok
