- Jul 18, 2009
- 11,659
- 19,204
- HYMER B644
Thetford don’t produce one for A C200 I am told
Thank you for that really comprehensive reply. I have fitted 4 SOGs in the past, and but current van was factory fitted by Hymer and vents through the roof.On our current MoHo we had a SOG fitted at the SOG factory in Germany, as I was travelling across Germany and it was convenient to call in en route from last years Caravan Salon at Dussledorf. The engineer who did the fitting whilst we waited strongly advised that no chemicals should be added to the cassette.
The SOG website says:
The increased supply of oxygen that the activated ventilator causes to flow into the cassette during use accelerates the decomposition process of the tank contents to such an extent that the use of chemical additives is no longer necessary. Even when the toilet is not used, a system is provided that is constantly open towards the outside and thus guarantees the decomposition process.
Our SOG®systems use some aspects of the principle behind the activated sludge process used at sewage treatment plants and therefore create the ideal conditions for the removal and decomposition of faecal waste.
Most sanitary cleaning products generally interfere with the bacteria used in sewage treatment plants. Some substances are more disturbing than others, depending on the concentration and amount used and how frequently the products are used. They are therefore particularly problematic for smaller sewage treatment plants located in popular tourist locations, which are mostly only suitable for use in villages. If too many travellers in these locations send a mixture of faecal matter and environmentally unfriendly concentrated cleaning products containing biocides to the treatment plants, this will cause the plants to become unstable.
It also offers advice as to the possible cause of any smells:
If, despite the SOG® system, unpleasant smells are to be perceived, especially when opening the toilet, these smells do not come from the cassette, but from the bowl. The toilets, especially the C260, C220 and C400, are completely closed by the lid, no more oxygen can get into the toilet. Since small remains of urine always stick in the toilet, the lack of oxygen leads to the formation of unpleasant odors. Warmth or hot temperatures in summer, or the use of heating in winter (the heating pipes often run in the immediate vicinity of the toilet, so that the toilet warms up) promote the formation of odors.
This problem can be eliminated by leaving the lid open or by attaching small rubber buffers below the lid so that oxygen can flow in.Polishing the bowl using a window polish for acrylic glass panes also helps, as the urine can then no longer stick so easily.
We have never experienced any smells, do not add chemicals, often go for 3 or 4 days between emptying when wild camping and, when necessary because there is nowhere convenient to dump correctly, we use a second cassette, keeping the full one for a few days longer in a plastic box with a sealable lid in the garage.
But as soon as you start to add any chemicals into the cassette you start to inhibit the natural decomposition processes. This results in some smell, leading to the idea that it is essential to empty every day (or even more often) and the inclination to solve the problem by adding more chemicals.A small spray bottle of diluted Zoflora for the bowl and a splash of Bio washing liquid for the emptied cassette, the SOG does the rest!
