So I have OE TPM
Does anyone know if I put up the tyre pressures the light would go off without having to take the moho out for a spin, if I can do it stationary I’ll have a crack at the parameters over the weekend. If not it’ll have to stay on
The vehicle needs to be driven for around 5 to 10 mins to reset itself.
Ours are now at 75 psi no alarm yet
can i see somewhere in the Peugeot to confirm i have the tire sensors
TPMS is/was an optional extra on 'basic' and 'professional' level Boxers.
Does the warning light come on when you first switch the ignition on? (Don't know if it should or not, but it might be a clue!)
A bit of a twist, just been out to move my Moho and the lights gone off and all Tyers are 65psi.
It probably went off lats week when I did about 500 mls, didn’t even notice.
Mine was a much better ride with pressures at continentals recommendation, just a pity the computer won’t shut up:mad:
Might drop mine by another 5psi and see how it goes then
Thanks for the info , ive just been out to the MH and turned on the ignition and it lit up like a Christmas tree , so many lights and ive not got a clue what some mean, so i just thought i would just take a picture :)
Thanks for the info , ive just been out to the MH and turned on the ignition and it lit up like a Christmas tree , so many lights and ive not got a clue what some mean, so i just thought i would just take a picture :)View attachment 305645
I think the tpm light is just in the space under the 120 on the speedo. I could be wrong but yours doesn’t appear to have it fitted.
Thanks , what ill do next week is lower my pressures and drive it a bit and see what happens.plus ill fit my after market TPM i have from my last MH.
I think you're right - I think it's the mirror image location of the door open warning lamp.
In the right light, you can see where the symbol is, even when the lights aren't lit.
(from the link above):
If @Bart has the base vehicle handbook, the location should be in there, too.
