Have my French and German air stickers - in plain English where should they be stuck ?
Ditto that.....Bottom right hand side of windscreen as your sat in the seat.
......and again.Mine are fixed in bottom corner of screen on left looking from the front of the vehicle from outside, which I believe is correct.
What everybody else said - bottom right hand side of windscreen as you look forward from inside the van.Have my French and German air stickers - in plain English where should they be stuck ?
Actually that's the near side so far as the relevance of the stickers are concerned.
Agreed if LHD but as mine is RHD and I'm guessing the OP's is also RHD then it's Offside.Actually that's the near side so far as the relevance of the stickers are concerned.
Yes, but where you will be using them will be the oppositeAgreed if LHD but as mine is RHD and I'm guessing the OP's is also RHD then it's Offside.
That's what I didI fitted all 3 of mine on a strip of perspex and they go from bottom corner upwards attached to screen .saves having to get new ones when the screen needs changing.
Richard, I laminated mine, then placed then in clear tax disc pouches, which stick to the windscreen.I fitted all 3 of mine on a strip of perspex and they go from bottom corner upwards attached to screen .saves having to get new ones when the screen needs changing.
What are Air stickers ?
