Side Marker Lights not working
Elddis Autoquest
Hi All,
I should be grateful if you could help me out with an issue on my Elddis Autoquest 2014 in which the top front, back top and bottom (orange) marker lights are not working. The only thing I could find to be a problem is that a 10 amp fuse was blown by the driver side / below safety belt wiring loom (see photo / yellow circle) and although I replaced the fuse it blew straight away when I put on the lights (from the main light stalk).
I then took out the bulbs which all appear to be working, and disconnected the earth wire on the bottom marker lights. Unfortunately, when I tried a new fuse to what I thought would be a bulb free system, the fuse blew again.
Although, this may be a visit to the Dealership, but I thought I would check with you guys first for any thoughts?
Thanks.
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
It could be worth looking at the wiring to see whether you have a cable trapped ,& shorting,somewhere?
I would also be surprised if that fuse was anything to do with the vehicle wiring?
Don't own one yet
newbie
Afternoon, just a quick question do you have a tow bar fitted?
Cheers
K
Elddis Autoquest
Hi, Thank you for your reply, and yes there is a tow bar fitted to the MoHo, but I don’t use it myself, as it was fitted before I purchased it. Thanks again.
Don't own one yet
newbie
The reason I ask is I had a very similiar problem with my swift. Indicator on and top marker light would flash, press lock on fob and break lights would flash and several other combinations. So checked the main under body socket from the cab to back of MOHO and also the earth from this socket all was good. Then discob=nected the tow bar electris from inside the garage area and everything worked fine. Plugged the tow bar back in and problems back again. So disconnected the tow bar and inspected the actual plug and found several wires that were loose. Re-tightened them all and a good clean and everything worked fine. It supprised me that this could cause so many small light problems but I suppose that electrics.
Good luck
K
Elddis Autoquest
Great, and much appreciated and I’ll will check out the the tow bar plug tomorrow.
Two on Tour
Elddis Autoquest 175
Hi All,
Thanks.
Normally, the top and bottom marker light on an Elddis are fused in the CBE SRX 250 relay unit, which is at the bottom of the driver's side "B" post behind the black plastic trim.
K
Elddis Autoquest
Brilliant and thank you, and this is another one to go on my checklist.
