Side marker light bulb replacement Hymer (1 Viewer)
Hils and Glenns
1,431
74,008
N Yorks
Hymer B 674
Does anyone know how to remove the cover on this light to replace the bulb please? Its near the roof on the side. Not really sure what its called. I can see screws inside the cover but don't know how to get at them. Thank you
Hils and Glenns
Hils and Glenns
1,431
74,008
N Yorks
Hymer B 674
I can't see any screws in the photo. Does the cover spring off - thin bladed screwdriver?
Thanks for your response. It might spring off. I was hoping someone knew the answer before having a go. My husband isn't handy and is quite clumsy :rolleyes: so it helps if he knows for certain before he has a go. :giggle:
Lisa
3,203
16,642
La La Land
Rapido A class
20th Sept 2014
DavidG58 might know, I'm sure he's knocked a few off in his time :ROFLMAO: :ROFLMAO:
Terry's not too sure if it just unclips, so wouldn't like to say....
Hils and Glenns
Hils and Glenns
1,431
74,008
N Yorks
Hymer B 674
icantremember
8,450
18,078
Near to Watton in Norfolk
Hymer T-SL668
since 2005
That looks like it. Thanks. I bet you can't replace the bulb and you have to buy the whole thing. Not that expensive though I suppose. There again it looks like a not very important light. Thanks everyone.
Except mine failed an MoT 'cos it wasn't working and the ba&*cards charged me for a complete lamp.:mad:
39
69
Shropshire
Since 2019
Good to hear that you have discovered that it just pulls off. I had the same problem but when I replaced the bulb it was still not working :(. I checked with a multimeter and found that the power was not getting through to the light. I have never found whether it was a fuse or some failure in the (difficult to access) cabling. I ended up splitting the cable for the light on the other side and powered both from the single supply. If anyone knows if there is a separate fuse I would be pleased to hear. If you find the same problem as I had, then the information about splitting the supply might be useful.
157
217
Dorchester
since 2010
We had the same light fail on our van. Used a extra thin paring knife from the cutlery drawer and the cover / lens twisted off with no damage. There were some loose bits inside which had to be refitted It was an ordinary torpedo shaped bulb similar to an interior light.
Don't forget to put the cover back on with the red lens showing to the rear. As if you don't know, obviously I got it wrong.
Surprisingly straitforward.
