Shurflo Water Pump Running Constantly (9 Viewers)
Feb 13, 2024
46
41
Looking
Hi,
As the title says, water pump keeps running even when taps are off.
There was a few drips from the filter/sieve and some debris in the sieve that looks to have been a seal from somewhere. Tightened up the sieve and no more drips but pump still runs endlessly.
When the taps on I think it looks like air might be getting in somewhere too. Any suggestions about next steps? Do I need to go hunting through all the pipes looking for a leak?
MichaelT
4,082
8,677
Colchester
Carthago I 143 LE
Since 2016
Hi,
Yes on hot side normally.
4,216
6,974
Rochester
Auto-Trail Mohawk
17 fun filled years
I would think it's dragging air in on the suction side if you dont have a leak on the pressure side.Try the little filter on the suction side, unscrew the plastic cup to see if there and cracks and make sure the O'ring is ok.
R
Feb 13, 2024
46
41
Looking
Ok that makes sense. Presumably the thing in the sieve that looked like a chewed up seal came from the suction side. Not obvious where it's from but will try and figure it out.
This is the pump and sieve if it's helpful.
R
Feb 13, 2024
46
41
Looking
Could the thing in the sieve be it’s own seal breaking up?
Yes possibly. Just had a breakthrough. Tightened up the sieve as much as humanly possible and seems to have temporarily solved the problem. Will look to get a new seal soon.
4,216
6,974
Rochester
Auto-Trail Mohawk
17 fun filled years
Yes there is a thin O'Ring that should be seated inside the plastic clear part, it just unscrews. The Oring is orange in the photo.
Here it is on Amazon
