Good question. What are hymer walls made out of? The old one was just screwed in to the wall inside a cupboard but that was just a light thing. This is a bit heavier.What are you fixing it to? Is it wood or metal? Can you access the back of it?
Old ones the inner wall is ply, new models from 2016 the inner wall is aluminum. The first one with Aluminium sandwich walls was the Dynamic Line in 2016, followed by the updated Exsis in I think 2018, I think most of the range now has the alloy sandwich.Good question. What are hymer walls made out of? The old one was just screwed in to the wall inside a cupboard but that was just a light thing. This is a bit heavier.
Well whatever I've screwed in to it seems to be holding. I just made fresh holes in the frame of the MPPT and used small screws to fix it.Old ones the inner wall is ply, new models from 2016 the inner wall is aluminum. The first one with Aluminium sandwich walls was the Dynamic Line in 2016, followed by the updated Exsis in I think 2018, I think most of the range now has the alloy sandwich.
if it was aluminium you would have had to drill a pilot hole.Well whatever I've screwed in to it seems to be holding. I just made fresh holes in the frame of the MPPT and used small screws to fix it.
Not sure what you mean, maybe this will help. If you had a 24V system, it usually is two 12V batteries in series. It is useful to monitor the midpoint voltage, to see that both batteries are OK. In a 12V system like yours it's not necessary - both batteries are at the same voltage because they are linked.Why is it showing an aux input from starter battery?
