- Jan 31, 2016
- 2,066
- 3,742
- Hymer B534 DL (2017)
- Well travelled
Has anyone fitted a shower, either externally or say in garage themselves ? would it be difficult ?
But how do you control the temperature if hot and cold are joined with no mixing control.I fitted one just inside one of our external lockers that was near to both the hot and cold pipe run.
Cut and fitted a push-fit "T" into hot and cold pipes and piped to the shower Bullfinch shower fitting.
That's got me thinking ... a problem with getting a shower is the amount of water that is wasted whilst trying to get the right temperature, not to mention nearly burning or freezing yourself in the process! If I could ascertain the exact time to have the boiler on to get the perfect temperature without having to add any cold water I'd save a load of water ... Might have to experiment a bit.Mine is a trauma single pipe shower hose, I connected it into the hot water pipe but to get the perfect shower temperature I just switch the water heater on for 5 minutes
I have the same thoughts. I bought one of these but not fitted it yet. Hopefully it will save water, but my primary concern was that my 10yo daughter can shower without help...That's got me thinking ... a problem with getting a shower is the amount of water that is wasted whilst trying to get the right temperature, not to mention nearly burning or freezing yourself in the process! If I could ascertain the exact time to have the boiler on to get the perfect temperature without having to add any cold water I'd save a load of water ... Might have to experiment a bit.
